2011 JK Unlimited-Poor Gas Mileage - JeepForum.com
post #1 of 12 Old 03-05-2014, 08:22 AM Thread Starter
tramark100
I have a 3.8 automatic 4dr, rag top, low restriction intake filter, performance exhaust. The vehicle has a 3" lift, running 35's.
Has anyone tried any of the performance chips or programing products to increase mileage and performance on a 3.8 V6? Only getting 14 to 15 miles per gallon average.
tramark100 is offline
post #2 of 12 Old 03-05-2014, 08:29 AM
JBTJ
For your MPG's, did you recalibrate the speedometer after you installed the 35's? If not, that's your problem.
As for performance, did you regear to accommodate for the 35's tires? If not, that's your problem there too.
None of those performance chips or programing products will do you one bit of good. Except make your wallet lighter.
JBTJ is offline
post #3 of 12 Old 03-05-2014, 08:41 AM
wilywillie
I get 15mpg in my '08, after it's been adjusted for 32" tires, and running 3.21 gears.... 2" lift, steel bumpers, winch, gear, etc. (lots of extra weight)
With an automatic, like LB said, using a computer flash will help with both your tire size and your "shifting", and if it's not calibrated already, you'll see a HUGE jump in perceived mileage. 15mpg in a 4dr with 35's is pretty darn good, though....be happy Atlanta's pretty flat:-)
I'm just here for the gasoline. --Max
wilywillie is offline
post #4 of 12 Old 03-05-2014, 08:53 AM
Jared89
2011 JK Wrangler
yeah i really dont know what the op is complaining about 15mpg isnt bad.
2011 rubi- 2.5" teraflex-35" nitto trail grapplers on xd addicts-shrockworks stubby bumper-20" light bar-TF proformance rotor kit - aluminum Psc crusher flares-
Jared89 is offline
post #5 of 12 Old 03-05-2014, 08:56 AM
cobra671
Lol!! That's what I get on my stock 2011 2 door rubi with a hard top and 32" tires. So I think he's doing pretty good with his tires.
cobra671 is offline
post #6 of 12 Old 03-05-2014, 09:08 AM
duneslider
If you aren't recalibrated for the tire size and if you haven't regeared that is where you should start.
i have a 3 inch lift and 35's and regeared to 5.13 and I typically get between 15-16.5. Over the last year my calculated average is 15.5. I drive pretty conservatively but cruise at 75 on the highway daily.
So, you really aren't too far off. I didn't see a huge jump in mileage regearing but it is much nicer to drive and my transmission temps stay lower.
The intake and exhaust probably provide no benefit to efficiency in these computer controlled jeeps.
duneslider is offline
post #7 of 12 Old 03-05-2014, 09:37 AM
JIMBOX
Heh Heh the old standby-My '08 JKUR/regeared/33.6" tires/weight avg 5600lbs-avg 17.2 mpg at 70 mph-
Dual cat-back exhaust/aux coolers/light foot-
The never ending story
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #8 of 12 Old 03-05-2014, 12:39 PM
planman
Thanks to all Mod erators
planman's Avatar
Regear to 5.13s or 5.38s to improve fuel economy on a '11 automatic with 35s.
Transmission downshifting/gear hunting is what kills fuel economy.
Regear to produce high enough engine rpm to produce enough power to reduce frequent downshifting, and fuel economy goes up.
planman is offline
post #9 of 12 Old 03-05-2014, 03:17 PM Thread Starter
tramark100
Approx price to switch to 5.13 gears
post #10 of 12 Old 03-05-2014, 04:11 PM
JBTJ
Area dependant, $1000~$1200 for both axles.
JBTJ is offline
post #11 of 12 Old 03-05-2014, 04:18 PM
planman
planman's Avatar
Like he said, the labor cost is area dependent.
You can get gears and overhaul/bearings install kits for less than $600.
It is rated at a 10 hour job. Experienced installers do it in less time.
planman is offline
post #12 of 12 Old 03-05-2014, 04:39 PM
JIMBOX
It'll depend on the State/County/shop/sales and what other diff work you might/should have done at the same time-
Price range from $1200 bucks to $2500 bucks and all ranges in between-
The type/quality/completeness of the regear--ie: full rebuild kits or ???
Do a lotta homework before making the decision, cause you don't getta money back guarantee for the wrong decision-
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
