-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   2011 JK front grill removal??? (http://www.jeepforum.com/forum/f96/2011-jk-front-grill-removal-1310465/)
joelynk 01-05-2012 09:27 PM
anyone have a video or website as to how to remove the front grill off my wrangler so that i can put some black mesh behind it to keep rocks from hitting the radiator?
i checked utube but found nothing.
is it a big job?
Charles 01-05-2012 09:34 PM
I just made a video for you. It's uploading.
BuckeyeMac 01-05-2012 09:39 PM
It takes about 2 minutes to take it off
Charles 01-05-2012 09:47 PM
It should be done processing soon.
joelynk 01-05-2012 09:59 PM
Great, i will wait for it. Thank you
DavidJeep 01-06-2012 04:52 AM
It is easy to remove ! The video is right on only advice I would give is when you install the mesh grill guard DO NOT over tighten the screws that hold the mesh to the grill because it destorts the bottom of the grill I am fussy about the way things look so I had to take the grill off a second time and then loosen the screws a little so it didn't destort the bottom of the grill now it looks like factory again !
DuraJeep 01-06-2012 06:32 AM
Use Loc-tite...
JeeperJusten 07-27-2013 11:30 AM
I have a winch, would i have to remove it? :(
mello 07-27-2013 03:00 PM
You can remove grill with a winch but it is a tight squeeze. At least it was on my 2011 with a winch but very achievable.
rirrgang 07-28-2013 09:23 AM
Simply remove the top screws and gently pull the bottom out. The bottom is held in with clips not screws
sqdnguns 07-28-2013 09:35 AM
Don't forget the remove the turn signal lamps as well. Just did this myself yesterday, looks good.
Filthy-Beast 07-28-2013 04:23 PM
put a towel over the winch so you don't scratch the paint of the grill.
rirrgang 07-28-2013 04:54 PM
I thought the signal lights might be tmi :)
The time now is 02:33 AM.
