2011 Blue Ox Base PLate - JeepForum.com
post #1 of 7 Old 10-05-2010, 02:00 PM Thread Starter
dbritsch
2011 JK Wrangler
Does anyone know if jeep made any changes from 2010 to 2011 on the front bumper mounts. I talked to Blue Ox and they have not installed a base plate (for towing) on any 2011 wranglers. I would think that the 2007-2010 base plate should fit the 2011 any opinions??
dbritsch is offline
post #2 of 7 Old 10-05-2010, 02:31 PM
LarryGrant
bring yours there for them to use yours as a test and get it free
LarryGrant is offline
post #3 of 7 Old 10-06-2010, 06:44 AM Thread Starter
dbritsch
2011 JK Wrangler
Thats what they said! Only problen is that they are in Nebraska and I am in Utah. A bit of a drive for a $350 dollar part.
dbritsch is offline
post #4 of 7 Old 10-06-2010, 06:04 PM
txdutt
2015 JK Wrangler
I know there was some change for the base plate install onto 2010's from the 07-09's (same plate just some mounting differences). Hard to imagine something else on the frame would change again to the 11's....
2015 Rubicon Unlimited-Fire Cracker Red
txdutt is offline
post #5 of 7 Old 10-06-2010, 07:07 PM
TestDummy
Jeep Geek
TestDummy's Avatar
2011 JK Wrangler
I agree. Find a place that will let you return it if it doesn't fit. You should be able to confirm it will fit without taking the bumper off or marking up the baseplate. I just took off the factory bumper on a 2011 and replaced with one from LoD (with Blue Ox tabs added as a custom mod) and everything went according to 2010 and prior instructions. I had the 2010 Blue Ox baseplate install instructions printed to use and compare to others I'd seen on-line and I didn't see any differences. Only issues might be if the holes in the side of the frame rails have moved, as it wasn't necessary to use those on the bumper install.
Ron
TestDummy is offline
post #6 of 7 Old 10-07-2010, 06:20 AM Thread Starter
dbritsch
2011 JK Wrangler
Thanks for the replys. The main issue would probably be hole position, and it sounds like it should not be a problem.
dbritsch is offline
post #7 of 7 Old 10-07-2010, 05:07 PM
SoonerYJ
SoonerYJ's Avatar
2011 JK Wrangler
I just installed a Rock Hard full length bumper and Warn Power Plant on my 2011 and had no issues with fitment.
The only part I've installed that didn't fit correctly is Rugged Ridge rear slush mats, they're way too small.
___________
2011 Flame Red Rubicon (2-Door) with every option.
SoonerYJ is offline
Need Help w/ Winch Bumper,Base Plate, & Braking System devarona JK Wrangler Technical Forum 1 02-12-2010 04:25 PM
Base Plate Question Oceanedge TJ Wrangler Technical Forum 4 12-13-2009 07:37 AM
base plate vs aftermarket bumper TJDaveX TJ Wrangler Technical Forum 0 12-19-2007 10:26 AM
Black and Blue (Well at night they're Blue!) JaySpencer66 YJ Wrangler Technical Forum 5 03-14-2006 02:18 PM
