2010 JKUR Highly Active Rad Fan - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2010 JKUR Highly Active Rad Fan
1993-2004 Jeep Grand Cherokee Steering Damper Trail Boss (50" LED CREE Light Bar Pair With Wiring KitSteering and more from Ruffstuff!
Unread 04-03-2015, 01:13 PM   #1
cherrybomb05
2010 JK Wrangler
Hey guys, need your advice once again. A few months ago I was goofing around and I ended up stuck in the snow. Long story short I ended up frying a fan circuit. I had it replaced and ever since then the radiator fan comes on after about 15 minutes of driving, will run for a little bit and then shut off. 10 minutes later it will do the same thing. Temperature doesn't matter. I replaced the thermostat and that didn't do it. I'm at a loss here!!
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 04:32 PM   #2
ronjenx
ronjenx's Avatar
The first thing to consider, is what is the actual temp of the engine when the fan comes on. You can check that with an infrared temp gun. Point it at the area around the base of the thermostat housing. That is where the temp sensor is, too. Do that after a cold start, and while it's idling, keep an eye on the infrared gun, pointing and checking it every 30 seconds or so. If the fan comes on before the temp reaches about 215F, the temp sensor may be sending a wrong signal. The fan should stop when it cools the engine down to about 195F.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 04-03-2015, 08:42 PM   #3
cherrybomb05
2010 JK Wrangler
Never thought of the sensor. I'll have to try that. I'm sure someone in the Jeep Club has a infared gun. Thanks.
07 WK
10 JKUR
11 JKR
