2010 JK Unlimited Rubicon lift help!? Aev 3.5" with 35s or 37s? - JeepForum.com
post #1 of 15 Old 02-03-2012, 09:33 AM Thread Starter
White_Rubicon16
Been doing a lot of research and it seems the the Aev premium lift would suite me best, however I would like to hear other's thoughts and opinions. The 3.5" kit should work great but then comes the question of whether I run 35x12.50 or 37x12.50? Anyone running this setup with any input and pictures would be much appreciated! I've been looking into Nitto trail grapplers but any other suggestions for tires would be great as well! Thanks for your time.
White_Rubicon16 is offline
post #2 of 15 Old 02-03-2012, 09:41 AM
HOKIES2010
2011 JK Wrangler
You can run 35s with stock fenders and 37s with flat fenders. If going the 37s route make sure to look at what you might want to do to beef up the D44.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #3 of 15 Old 02-06-2012, 12:49 PM Thread Starter
White_Rubicon16
What exaclty would i need to beef up?
post #4 of 15 Old 02-06-2012, 01:14 PM
RubiNoob
2010 JK Wrangler
I have a 2010 JKUR with AEV 3.5" lift and 35" tires.
I've just upgraded to 5.38 gears and had the front axle sleeved and gusset'ed.
After the gearing, I'd say I am 110% satisfied.
BTW, if you're asking these questions, go with 35" tires. Once you wear out the 35" tires, you'll know all you need to in order to decide if you want to go to 37s.
RubiNoob is offline
post #5 of 15 Old 02-06-2012, 01:24 PM
HOKIES2010
2011 JK Wrangler
Can look at inner/outter sleeves, c-gussets, HD ball Joints, axle shafts, HD knuckles, truss and I am sure there is more. I went with everything above other than the truss and I am going to order new axle shafts at some point, probably after I break the stock ones. There are alot of guy on here with more knowledge than myself. I have read numerous reports on the stock ball joints being junk and the front D44 having issues with the tube and Cs with 37s (bending an twisting under the load). Some guys on here will tell you that you need to start looking into to hydro assist as well. I personally have no plans for it at the moment.
My Build
post #6 of 15 Old 02-08-2012, 12:19 PM Thread Starter
White_Rubicon16
Thanks a lot i'll start looking into those options!
Any Pics? What was the cost of the lift and tires? And cost to regear? Just trying to get a rough estimate if i can thanks i appreciate it.
post #7 of 15 Old 02-09-2012, 01:50 PM
fish88
I'm running the AEV 4.5 with 37x12.5 MTZ's- re-geared to 5:13
If you plan to offroad you will rub with 3.5 and 37s.
I have not done anything yet to strengthen the D44. To my knowledge, most of the guys that change inner/outter sleeves, c-gussets, HD ball Joints, axle shafts, HD knuckles, truss etc. have problems with running the D30 stock with 37's. I could be wrong though as am I am sure there are a lot of guys here who know better.
fish88 is offline
post #8 of 15 Old 02-11-2012, 10:48 PM Thread Starter
White_Rubicon16
WOW !!! great looking rig and thanks for your input ! How much would you say it cost you to lift, get tires, and regear?
post #9 of 15 Old 02-12-2012, 08:34 AM
KPJ
2010 JK Wrangler
You can run 37's on the 3.5" AEV suspension with oem fenders if you use the interchangable rear bump stops in the 4.5" position, this according to AEV. And Dave Harriton drove a 3.5" lifted, 37" tire 2 door diesel at EJS last year....
I run AEV's 4.5" suspsension and 37's on the stock D44 and no issues so far. Rather than beefing up the oem D44, if/when I bend the tube I'll upgrade to a Dynatrac. It's the tubes that are the real weak point.
JPK
KPJ is offline
post #10 of 15 Old 02-15-2012, 01:17 PM
fish88
White_Rubicon16 -
Thanks...
Doing the work yourself can definitely save - as I did... If you have it done, figure $15K which includes front and rear bumper/tire carrier with winch. I did it for slightly less.
fish88 is offline
post #11 of 15 Old 02-15-2012, 01:25 PM
fish88
Re-gearing typically runs around $1200. +/-
Wheels/tires depends on type but AVE + 37 MTZ's ran around $680 ea. set
4.5 AEV Lift alone w/o install $1800 - (recommend upgrading to reservoir shocks +$)
Hope this helps...
fish88 is offline
post #12 of 15 Old 02-15-2012, 01:32 PM
bconrad5150
2010 JK Wrangler
Just lifted mine with the 3.5" and 35" Duratracs. Threw in some 5.38's as well. It rides great. I am very satisfied. I will try and get some pics soon.
bconrad5150 is offline
post #13 of 15 Old 02-15-2012, 03:29 PM
KPJ
2010 JK Wrangler
Hope this helps...
According to Dave Harriton, AEV chief and founder, you don't need the remote reservoir shocks unless you spend a lot of time running fast washboard, like the long desert trails where mono tubes can experience fade from heat build up...
I have the AEV 4.5" suspension and 37's and in 42k miles I have experienced no fade on the mixed terrain I have run with the mono tube Bilsteins, and fade is what the remore reservoir shocks are designed to prevent.
JPK
KPJ is offline
post #14 of 15 Old 02-24-2012, 11:53 AM Thread Starter
White_Rubicon16
Thanks for all your input, great info!
post #15 of 15 Old 02-24-2012, 11:55 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
I'd say hydro assist is pretty close to a must. I'm just running 35's and have been in plenty of situations where I wished I had it...its on the short list.
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
aev , lift kit , rubicon , unlimited , wrangler jk
2010 rubicon unlimited CaseyC6 JK Wrangler Technical Forum 0 03-04-2010 06:05 PM
2010 Unlimited Rubicon xinys JK Wrangler Technical Forum 2 12-14-2009 11:02 AM
Want lift 2006 Wrangler Rubicon Unlimited 2" to 2.5". Need lift system advice. CB3 TJ Wrangler Technical Forum 8 04-19-2007 08:44 PM
Unlimited Rubicon , 3" Black Diamond lift , 35" Hankook tires , Commander Hulk wheels RedRockJK JK Wrangler Technical Forum 67 03-25-2007 10:39 PM
Rubicon Unlimited lift with 35" tires todds21 TJ Wrangler Technical Forum 14 07-29-2005 10:57 PM
