2010 JK Fuel odor after 1 -2 hours on trail at low speeds - JeepForum.com
post #1 of 8 Old 08-14-2012, 11:25 PM Thread Starter
calemasters
I have noticed a fuel odor at the back of the Jeep after being on a trail for 1 to 2 hours at low speeds. I assume this due to evaporative system not being able to purge the charcoal canister due to low vehicle speeds.
I do not have a check engine light, no codes and no known problems. As soon as I leave the trail and return to highway speeds the order stops. The fuel cap is good and seals properly to the filler neck. The canister is well protected by a skidplate. I do not top off the fuel tank. Fuel level is about 1/2 to 3/4 when I am on the trail and have noticed the gasoline odor.
Does this seem normal? Anyone else noticed this condition?
calemasters is offline
post #2 of 8 Old 08-15-2012, 03:31 AM
OH9JK
2009 JK Wrangler
Is it a raw fuel smell or exhaust smell?
OH9JK is offline
post #3 of 8 Old 08-15-2012, 07:40 AM Thread Starter
calemasters
Gasoline odor, not exhaust.
post #4 of 8 Old 08-15-2012, 11:45 AM
1222
RIP John
1222's Avatar
I had the same problem with my 08 a lot and once so far on my 12. I have also heard of others with the same problem so I think its not that uncommon. I do believe that it has to be a very hot day for that to happen too. Sometimes it can become pretty bad to where youd think that you have fuel leaking but of course it isnt.
1222 is offline
post #5 of 8 Old 08-15-2012, 11:51 AM
1AAdam
interesting maybe the evap system is where it's coming out?
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #6 of 8 Old 08-15-2012, 01:17 PM
paul84043
Never had that problem, but I do know that if you can smell it that strong..the concentration has become enough to potentially be dangerous.. Probably worth a second look at least...
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #7 of 8 Old 08-15-2012, 01:55 PM
Wavedatya
2010 JK Wrangler
^^^. Yeah. That's not good. You shouldn't smell fuel like that. Unless when you filled up you got gas on the outside.
I have honestly never heard o that. I know a few people have had issues with these gas tanks. Maybe a busted line?
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #8 of 8 Old 08-15-2012, 03:08 PM Thread Starter
calemasters
Originally Posted by 1222 View Post
I had the same problem with my ’08 a lot and once so far on my ‘12. I have also heard of others with the same problem so I think it’s not that uncommon. I do believe that it has to be a very hot day for that to happen too. Sometimes it can become pretty bad to where you’d think that you have fuel leaking but of course it isn’t.
Yes, we have had high ambient temperatures when this occurs.
It seems to be coming from the charcoal canister.
Fuel Pump Replaced- Now gas odor??? cmedeiros17 YJ Wrangler Technical Forum 6 10-14-2009 12:08 PM
Fuel odor shinigami YJ Wrangler Technical Forum 4 12-02-2006 12:58 AM
Strong fuel odor JeepZJlover TJ Wrangler Technical Forum 1 07-04-2005 02:31 PM
Raw fuel odor Afishinado YJ Wrangler Technical Forum 7 01-10-2003 10:59 PM
raw fuel odor Afishinado YJ Wrangler Technical Forum 3 04-08-2002 05:42 AM
