2010 Heater Not blowing Hot Air - JeepForum.com
post #1 of 14 Old 01-17-2013, 03:36 PM Thread Starter
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Its luke warm at best... Thankfully, it has a couple months left on the bumper-2-bumper warranty, so its over at the dealership now. They just called and said they looked and couldn't find anything wrong with it...No coolant leaks, thermostat is fine, etc.... So now they want to keep it until Monday, and tear the dash apart to see if the internal doors might be stuck.
Thought I'd throw it out to the community and see if any JK owners have had similar issues...
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #2 of 14 Old 01-17-2013, 03:52 PM
GPV
http://www.jeepforum.com/forum/f96/t...vents-1460802/
On the plus side you aren't alone.............
There have also been reports of sand from the casting left inside the block eventually plugging up the heater core.
Best of luck.
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #3 of 14 Old 01-17-2013, 04:43 PM
Godholio
Why do people keep throwing out the heater core idea? His heater is blowing hot air, but it's not getting to all the vents.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #4 of 14 Old 01-22-2013, 11:08 AM Thread Starter
MusicMaverick
2014 JK Wrangler
Confirmed... Its the heater core... But the reason it went bad is casting sand in the coolant... They're going to flush the system and replace the heater core.
Currently: '14 JKU
post #5 of 14 Old 01-22-2013, 04:13 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
The self check on the heater is REAL simple. remove the glovebox door (squeeze the side stops inward and lower it).
Then cycle the heater defroster ac etc and see if the diverter is working. On heater mode you should NOT be able to hold your hand up next to the core without a five second discomfort from too hot - if warm, not enough coolant flow. If hot but the heat does not come out - motor controller switch etc for the diverter.
My 11 froze the motor at ~7k miles and dealer replaced under warranty - after I spent an hour playing with it and scalded my fingers twice. Yep - Im a slow learner....
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #6 of 14 Old 01-22-2013, 04:26 PM
442Wrangler
In like Flynn.
442Wrangler's Avatar
x2. If the core is blocked, no heat will come through it at all.
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #7 of 14 Old 01-22-2013, 09:05 PM
wranged
2015 JK Wrangler
2010 Heater Core JKU
Just had mine replaced under warranty. Driver side was blowing lukewarm air at defroster and foot well. Dealer added a "solvent" in the coolant to run for a week in an attempt to dissolve whatever is clogging the cores. No dice!! Took it back and they replaced the core. All is good now and just in time for CCCOLD weather in PA.
wranged is offline
post #8 of 14 Old 01-23-2013, 07:11 AM
jstrubberg
2009 JK Wrangler
Yet another case of a dealership that can't think...
There is ONE heater core. If any part of the vehicle is getting hot air, the problem isn't the heater core!
You've got a blend door sticking somewhere. They probably broke it loose moving things around. I hope the problem doesn't come back, because they didn't fix it.
When did mechanics become idiots? My dad did this for 30 years and I did it for four. No one thinks their way through a problem anymore.
jstrubberg is offline
post #9 of 14 Old 01-25-2013, 05:04 PM Thread Starter
MusicMaverick
2014 JK Wrangler
Well, they replaced the heater core. It works great now... I think that was the issue. The heat was progressively getting worse over time, by the time I brought it in, it was almost non-existant.
Currently: '14 JKU
post #10 of 14 Old 01-25-2013, 07:41 PM
jstrubberg
2009 JK Wrangler
If the air was lukewarm at all the vents, then it's entirely possible that the heater core away the problem. If, as you said, it was only the drivers side, then replacing the core didn't do a thing and the issue will likely return.
There is one heater core. It feeds every vent in your vehicle. You cannot have two different temps out of the vents and have a heater core issue.
post #11 of 14 Old 01-26-2013, 09:12 AM
wranged
2015 JK Wrangler
I always understood that there is one heater core and it did not make sense to me that the core was the problem. All I know is that, according to the work order, they replaced the core and a switch and I now have plenty of heat. Perhaps the switch fixed the blend door.
wranged is offline
post #12 of 14 Old 01-26-2013, 09:11 PM
nickmonaco
Same problem with mine. Just had it fixed. Heater core and cooling system flushed about 3 times. That did it. Now I'm toasty again.
WHITE JEEP CLUB #171
My other Jeep's not a Chrysler.
nickmonaco is offline
post #13 of 14 Old 04-24-2013, 09:28 AM
CrawlingForward
Bump for an old thread, as I'm running into the same issue with our 2010.
nickmonaco, you said a bunch of flushing took care of it? (Our warranty just expired )
Anyone have instructions on how to flush the cooling system on the JK? I've done it on TJs, anything different?
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #14 of 14 Old 04-24-2013, 06:17 PM
scorpionkill
scorpionkill's Avatar
I was having this problem with my 2008. I discovered after smelling antifreeze that I was loosing coolant but I couldn't see for the life of me where I was loosing it. One day jeep temp got scary hot and heat started blowing ice cold. Got out and heard hissing. I had a pretty decent coolant leak on the front passenger side where the lower intake met the head. I replaced the coolant but then had airlock and kept having the temp go up and loss of heat. Drove like this until I could address it. Had the intake gasket replaced today to the tune of $597.00. I'm glad I had the 4x4 place do it because a bolt broke in the motor and needed to be drilled, it would have been a giant headache for me.
2008 JK X 2 door, 1997 TJ
scorpionkill is offline
