2010 fog lights - aftermarket replacement bulbs available? - Page 2 - JeepForum.com
post #16 of 19 Old 12-10-2010, 06:37 AM
Vin
Originally Posted by Hilldweller View Post
You can do better than Sylvania bulbs with almost any other bulb.
I only mention Sylvania because it's still 1/3 the price of a OEM bulb from Jeep. That would be my main reason for retrofitting an '07-'09 foglamp housing into my '10 Jeep. Eventually I'll have othey Aux lights to light up the night. I was just wondering if anyone has done it yet.
Vin is offline
post #17 of 19 Old 12-16-2010, 08:59 PM
t_james_33
2010 JK Wrangler
if you go to canadian tire, tell them you want to order a h16, arctic white nokya stage 2, they can order it thru keystone for about 50 bucks. takes about 3-4 days for shipping and you do need to file down the tabs a bit. i have dont this myself and they work great!
t_james_33 is offline
post #18 of 19 Old 05-27-2013, 06:01 AM
sonetx
Originally Posted by Vin View Post
I was contemplating getting a set of 07-09 fog lamps with wiring and trying that. Anyone ever do this?
Old post but, it could use an update.
Yep. Did it on my 2011 jk. Running 9145 silver stars. It has been working fine for over 2 years. The 9145 pig tails can be found at Pep Boys.
sonetx is offline
post #19 of 19 Old 05-31-2013, 03:51 PM
EagleRiverDee
2011 JK Wrangler
I changed mine using H16's on my '11. I had to do some creative shaving on the tabs to make them fit in the housing, but I've had no electrical issues from the change in voltage and they've been installed over a year and got run daily during the winter. Take your old bulb out and just shave the tabs on the new bulb to match and it'll work fine.
EagleRiverDee is offline
2010 Foglight bulbs dansrt JK Wrangler Technical Forum 1 08-18-2010 06:51 PM
aftermarket headlight/foglight bulbs wrangler10 TJ Wrangler Technical Forum 6 12-14-2009 05:03 PM
What Kind Of Bulbs Are These In 2010 Wrangler Fog Lights? jcull35 JK Wrangler Technical Forum 1 12-03-2009 02:29 PM
Replacement Fog Bulbs DominicR JK Wrangler Technical Forum 7 08-13-2009 03:14 PM
IPF H4 Replacement Bulbs jfarrell YJ Wrangler Technical Forum 6 06-13-2002 12:56 AM
