2010 factory soft top - JeepForum.com
post #1 of 4 Old 06-01-2013, 09:07 PM Thread Starter
twokids
1983 CJ7
Is there a trick to get the latches in the front to latch???? It's like everything need to go forward about a half an inch and I can't get anything to budge. Thanks for any help. I am sure it is something simple but I can't figure it out.
twokids is offline
post #2 of 4 Old 06-01-2013, 09:14 PM
DrHolliday
2011 JK Wrangler
Leave the rear corners out and rock the whole top forward. That's always worked for me.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #3 of 4 Old 06-01-2013, 10:38 PM Thread Starter
twokids
1983 CJ7
I did try that but then the corners are up to high to get in. Is there not a way to tighten the bow assembly after it is all fastened (like you can on all the older jeeps?)
twokids is offline
post #4 of 4 Old 06-01-2013, 11:34 PM
Vin
It'll stretch out eventually. I used to latch the front first, the. when it came time to connect the rear, I would pull down from the top until the corner would reach. It's probably easier with a second person, but still doable by yourself.
Vin is offline
