2009 Jeep Wrangler 4 door unlimited mopar nerf bars don't fit - JeepForum.com
post #1 of 4 Old 04-25-2009, 08:42 AM Thread Starter
brentashley2000
I bought a set of mopar nerf bars for my 2009 jeep wrangler 4 door. they actually stated they were for '07-08 4door jk. the body mount in the rear has a threaded hole and works fine. the middle and front body mounts have the holes but they are larger and not threaded so i don't know what to do. thanks in advance for replies. is there a difference on the jeep bodies from 07-08..i wouldn't think so but who knows.
brentashley2000 is offline
post #2 of 4 Old 04-26-2009, 08:03 AM
1star2
Do the holes line up? Did you buy it new or used? If it was used you might be missing some hardware. If you bought it new I would call the place that you bought it from and tell them you are missing the hardware. I had a TJ that I bought some used factory running boards for and the hardware that goes into the hole was missing.
1star2 is offline
post #3 of 4 Old 04-26-2009, 09:39 AM
gpb
Not sure about nerf bars, but the side steps for the unlimited require threaded clips that go in the body holes for the forward two of the three underbody mount points
Have a look at http://www.quadratec.com/Assets/Installation/75628.pdf to see what I'm talking about.
gpb is offline
post #4 of 4 Old 04-26-2009, 09:41 AM
gpb
Found the tube step directions, they also refer to the clips: http://www.quadratec.com/Assets/Installation/75620.pdf
gpb is offline
2009 Jeep unlimited-water leaks on front driver door and floorboard mphillips Wrangler General Discussion 12 03-08-2010 05:58 PM
2009 jeep wrangler unlimited hardtop storage options brentashley2000 Wrangler General Discussion 6 02-01-2010 01:24 PM
Cab Cover From Mopar Designed For The 2007 Jeep Wrangler 2 Door BillArf JK Wrangler Technical Forum 0 04-23-2007 06:26 PM
Unlimited Rubi - nerf bars/steps Ole Yeller TJ Wrangler Technical Forum 9 04-18-2006 08:05 PM
Unlimited and bumpers/rockers/nerf bars mdot TJ Wrangler Technical Forum 4 01-26-2005 07:43 PM
