2009 auto trans shudder problem HELP! - Page 2 - JeepForum.com
post #16 of 23 Old 01-27-2012, 06:33 AM
TWISTEDII
Originally Posted by ronjenx View Post
What you describe sounds like it's going into overdrive, then the torque converter locks up.
When you press on the gas pedal, the gearing is too high to get any acceleration. Further pressing finally makes it unlock, and possibly downshift.
I leave the overdrive off around town for this very reason.
I have also found that if I stab the pedal a little, (not to the floor), it will make it downshift a lot sooner than if I press slowly.
That's exactly what it feels like. I don't mean to hijack this thread, but is this a "problem" I should have looked at, or just the way the gearing is and TC is?
TWISTEDII is offline
post #17 of 23 Old 01-27-2012, 08:16 AM
ronjenx
ronjenx's Avatar
It's not a problem, as long as you don't get a vibration that feels like you are driving over a washboard. That would be a torque converter or software problem.
ronjenx is online now
post #18 of 23 Old 01-27-2012, 06:13 PM
WhiteJK
2009 JK Wrangler
Same problem here with the washboard-shudder. Normally at 40-55mph and backing uphill. I turn off od and this helps a lot. When I'm coming into town from hwy driving(at around 45mph) if I don't turn off od there are times the jk feels like it is going to shake apart if I stay on the gas. I'd take it in but I'm really tired of visiting the dealer and I just don't want to spend the money on a low mileage vehicle, which if I continue to ignore it I'm gonna probably pay more. This started at around 40,000 miles and I now have just over 50,000. I'm starting a help whitejk jeep fund. If I can collect enough money from you guys I'll go ahead and install a v-8 and tranny of you guyses choice.
WhiteJK is offline
post #19 of 23 Old 01-29-2012, 12:35 PM Thread Starter
KYJeepMan1
2009 JK Wrangler
UPDATE: We have driven over 200 miles after the reflash. So far it has'nt done it again. Well see if this takes care of the shudder issue. I have to say we really like the way this newer jeep drives and rides. But i do miss my 94.
KYJeepMan1 is offline
post #20 of 23 Old 02-01-2012, 01:41 PM
TWISTEDII
I just spoke to my local dealership and they said any software updates or reflashing is typically covered for 8 years. I'm taking mine in because I'm beginning to feel a little rumble strip feeling if I pay attention to it when my car does what I explained before.
post #21 of 23 Old 02-01-2012, 01:50 PM
ronjenx
ronjenx's Avatar
post #22 of 23 Old 02-01-2012, 03:44 PM
WhiteJK
2009 JK Wrangler
To be honest I was hoping you had the answer Ronjenx. You're like MacGyver's smarter brother.
WhiteJK is offline
post #23 of 23 Old 06-01-2013, 08:42 PM
jvandy50
2010 JK Wrangler
i have this exact problem and seems pretty common. has anyone here tried a shudder stop additive? we recently added some to a troublesome ford tranny and it worked wonders.
mine started doing this the day after i added a dynomax muffler, coincidence i know, but still weird
jvandy50 is offline
Trans Solenoid Problem ,Auto Trans Guys In Here gtospeeding TJ Wrangler Technical Forum 5 06-17-2010 07:33 AM
Auto Trans. Problem blazer8 TJ Wrangler Technical Forum 17 01-13-2007 09:55 AM
auto trans problem Help 4wheeler98 TJ Wrangler Technical Forum 7 10-13-2006 09:08 AM
Auto Trans Problem DaleB TJ Wrangler Technical Forum 4 01-07-2004 07:54 PM
