2009 3.8 Where's my oil going? - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2009 3.8 Where's my oil going?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 08-04-2013, 01:21 AM   #31
pentastarguy
2015 JK Wrangler
if anyone cares, my 08 uses 1/2 quart every 6000 miles, which is when i change the oil. 82000 miles on the odo.
pentastarguy is offline   Reply With Quote Quick reply to this message
Unread 08-04-2013, 09:25 AM   #32
Jiblet
Originally Posted by TRAUMAhead View Post
Same. 2010, burned no oil till about 55-60k, now it's 1 quart every 1k-1.5k miles. Been using Dino for all it's mileage, going to switch to synthetic on the next oil change.
have you checked (changed) the PCV valve?
Jiblet is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 12:22 AM   #33
TRAUMAhead
2010 JK Wrangler
I swapped it out about 5k miles ago, no change. I'm at 72k right now.
TRAUMAhead is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 12:23 AM   #34
TRAUMAhead
2010 JK Wrangler
Double post.
Unread 08-06-2013, 07:18 AM   #35
Jiblet
Bummer.
Another thought, if you do switch to syn after a long time with conventional, it's reported that the extra cleaning power in some syn formulations can expose otherwise hidden leaks.
Syn formulations generally require fewer viscosity modifiers in the add packs which leaves room for higher concentrations of detergents, etc.
I'm not suggesting the oil loss will get worse, just that it's a possibility.
