2009 3.8 Where's my oil going? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 2009 3.8 Where's my oil going?
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-23-2013, 01:25 PM   #1
xSoFx
1987 XJ Cherokee
I've read all about the oil consumption issues with this motor, but I'd like to delve a little deeper into the issue at hand. My motor seems to be consuming ALOT more than most, 1QT/250 miles. I have no leaks on the ground, the plugs are not fouled and have no smoke coming out of the tailpipe. I've checked for leeks around gaskets and have found nothing.
I did a full Seafoam treatment twice to no avail, not even a smoke show.
I've changed out the PCV valve since it was spitting oil into my air filter. I run 10W30 HM oil. Still the consumption continues.
So I'm just wondering where exactly it's going? I would assume out the exhaust, but it isn't smoking or anything of the like.
I will likely end up having to rebuild the motor but until then, I'll keep pouring oil in her and change the filter every 5k.
xSoFx is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 01:27 PM   #2
442Wrangler
In like Flynn.
442Wrangler's Avatar
Try 5w-20 like the cap says. I use this in my 08 and have never had the oil burning issue. If this doesn't work I would guess it has to be coming out of the exhaust unless a ghost is stealing it.
Also just for schitz and giggles, what is the compression in each cylinder?
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 01:29 PM   #3
xSoFx
1987 XJ Cherokee
Initially, 5w20 was in it from the dealership. I bought it used a month or so ago. I checked the oil when I got it and it was full. I checked the oil 2 weeks later and found nothing on the dipstick. I may try 5w20 again as it seems no matter what type/brand oil I use it eats it anyway.
Unread 07-23-2013, 02:17 PM   #4
442Wrangler
In like Flynn.
Did you try synthetic?
Does your coolant disappear as well?
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
Unread 07-23-2013, 03:27 PM   #5
SoK66
2009 JK Wrangler
Forget the 5w-20, it'll suck that out like like a five cemnt soda pop. You need to do a cylinder leakdown test & see if the rings are holding compression. If they are it's then likely you've either got bad valve stem seals, or some bad valve guides.
SoK66 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 01:55 PM   #6
xSoFx
1987 XJ Cherokee
I've just taken the jeep into the dealership (toyota) and they said they cannot do anything for me. Im being sent to the chrysler dealership right next door for testing. Im under a powertrain warranty which toyota will be paying for so I hope that chrysler will cut the BS and just give me a new motor. Wish me luck
Unread 07-24-2013, 02:23 PM   #7
T00THD0C
OK, good luck.
T00THD0C is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 08:19 PM   #8
SoK66
2009 JK Wrangler
Good luck. Be sure and report back.
Unread 07-26-2013, 04:24 PM   #9
xSoFx
1987 XJ Cherokee
So here's the news:
Chrysler dealership did diagnostic work and decided the motor needs to be pulled for internal work.
The dealership from which I purchased the vehicle(Toyota), does not want to pay for said work. They will attempt to contact the PO (a friend of the dealership's owner) and see if he ever made a complaint to Jeep under warranty. If so, they will try to force Jeep into paying for the motor work.
If that does not work, I have the option of letting them buyback the vehicle and take a trade of equal value.
Sadly, they are a Toyota/GM/Buick dealership so my options are few as far as replacement vehicles. It seems as though my Jeep life will be short lived.
Unread 07-26-2013, 04:47 PM   #10
montero1
2010 JK Wrangler
Originally Posted by xSoFx View Post
So here's the news:
Will you break even in the buy-back?
montero1 is offline   Reply With Quote Quick reply to this message
Unread 07-26-2013, 10:54 PM   #11
xSoFx
1987 XJ Cherokee
Yes, it will be whatever the purchasing costs were for myself.
Unread 07-27-2013, 01:09 AM   #12
pentastarguy
2015 JK Wrangler
you could always say no, "fix the engine". no way would i let them push me into another vehicle on their lot.
pentastarguy is online now   Reply With Quote Quick reply to this message
Unread 07-27-2013, 02:18 AM   #13
montero1
2010 JK Wrangler
I say new engine, or get your money back and go somewhere else and buy a Jeep.
Unread 07-27-2013, 09:25 AM   #14
Butterjeep
2015 WK
Be polite but firm. You paid for a Jeep in good running order. That is what you should get. If I buy a beer and it's flat, I don't want a glass of milk, I want a glass of nice cold crisp beer!
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline   Reply With Quote Quick reply to this message
Unread 07-27-2013, 10:53 AM   #15
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I have never found leeks on engines either. As far as that goes - No onions, garlic or kurrat either....
But seriously - sure hope you get some relief from the dealer though.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a hard knock...
jwmbishop is offline   Reply With Quote Quick reply to this message
