2008 JK starter problems at 42,000 miles - JeepForum.com
post #1 of 10 Old 06-28-2011, 11:50 AM Thread Starter
Cooneys08JK
Cooneys08JK's Avatar
Hey guys,
I have been having some issues with my jeep over the past 2 months. There has been an intermittent starter issue that has been bothering and I am worried I will be stranded sooner rather than later.
Sometimes when I go to start it the Jeep will crank once or twice and then start. Other times it will crank up to 4 or 5 times not start (when I say crank, its almost is the Jeep is hiccuping and struggling), then once I turn the key to the off position and try again it will start up just fine.
This morning it took 3 cranks to get going so I was starting to think that my battery is on its way out (original bat). I pulled into my regular D&Ds and when I went to start my jeep again I heard an awful metal on metal sound. Kinda like how it sounds when you go to start your car when it is already running. Once again I turned the key to the off position and tried to start it again, which it did without issue.
I just ran to lunch and it started with no issue.
FYI, once started the Jeep is running great with no issues to report.
Is there anything I can do to start eliminating possibilities?
Thanks guys!
'08 Black 2door JK- DD
'99 Chilli Pepper XJ- Wheeler- BFG ATs, 2 " BB + bolt on stuff
Cooneys08JK is offline
post #2 of 10 Old 06-28-2011, 12:06 PM
gogogooch
2009 JK Wrangler
I had a similar problem with my '02 Bonneville - turned out to be the fuel pump once I couldn't start it anymore.
gogogooch is offline
post #3 of 10 Old 06-28-2011, 12:43 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Well, fortunately you can't start a JK when it is running as the computer knows better...but, the metal on metal sound could be the Bendix gear going bad. Fuel pump would probably throw a code that could be read...have you checked to see if there are any stored codes?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 10 Old 06-28-2011, 01:10 PM Thread Starter
Cooneys08JK
Rocky,
Thanks for the reply. Yes and I love that feature of the JK because I did it with my TJ all the time!
I have checked for codes each time and nothing!
So I had to google the Bendix gear (sorry learning here) and I understand that it pushes into the flywheel ring gear to crank the engine, and by replacing the starter you replace the bendix gear, correct?
I would like to fix this myself to keep on learning, and seeing as my warranty has now expired. I do consider myself somewhat mechanically inclined, but I have no experience with starters. Could this be a simple driveway swap??
Thanks so much!
post #5 of 10 Old 06-28-2011, 03:53 PM
RockyClymer
RedRock4Wheeler
With some mechanical experience, some basic tools and a copy of the service manual (usually found on a CD) dropping a starter and checking it out is an easy job. Prior to that I would check your battery, connections, etc..so you do not go through an unnecessary job. But, basically it amounts to disconnecting the battery, then getting under the JK and removing the two bolts that hold it onto the bell housing and then removing the battery lead to the solenoid. The Bendix gear, starter and solenoid all come out as a unit.
NRA Life member
post #6 of 10 Old 06-28-2011, 04:38 PM
1222
RIP John
1222's Avatar
I would check the battery for cranking amps first like already mentioned. That (new battery) has fixed a lot of starting issues with the JKs. Its fast and costs nothing.
1222 is offline
post #7 of 10 Old 06-29-2011, 02:58 AM
mrsig
At 45,000 mine was staring funny too! The dealer put a new starter in and now it starts fine!
07 JKU To see mods & my Jeep in Action @
CEO of Black Sheep 4x4s
Member of CCJ, White Jeep Club Member #137.
mrsig is offline
post #8 of 10 Old 07-30-2013, 11:26 AM Thread Starter
Cooneys08JK
So I wanted to update this as the problem has returned.
This issue continued from my original post up until last August. In August of 2012 my Jeep was unfortunately struck by lighting, due to this I had to replace the TIPM, PCM, Wireless control module, ABS module and both of my keys.
After the repairs were performed I had a year of trouble free Jeepin and my starting issues literally vanished. Until last night..
The scratching noise has returned. I pulled into a gas station, ran inside for 2 minutes tops, and upon return I started my Jeep to an awful grinding sound. Exactly like how an older vehicle sounds when you turn the key with the engine already running. I turn the key back and try starting again, which it does just fine. It did the same exact thing this morning when I started it to go to work.
To me, this can't be a starter because the issue wouldn't just disappear after having the "brains" of my Jeep replaced. Maybe I am wrong..
Upon further research folks have brought up "dry start" related to a bad mopar oil filter. This could possibly make sense because a month ago I had my oil changed at a dealership while they were doing some extended warranty work and indeed have a mopar filter currently installed. Prior to that, I had napa filters installed. Have any of you heard of this? Do I have my facts straight?
If you look at my location you will see I live on Martha's Vineyard so taking it to a dealer is a $120 ferry ride + frustation getting a reservation in the midst of summer people. So my situation is not as easy as "take it to the dealer".
Any thoughts? Thanks guys!
Edit: I now have 71,000 miles on my Jeep. This issue started around 40,000 miles. Is it possible to drive 30,000 miles on a starter that was going bad? That's why I am thinking something else is the culprit.
post #9 of 10 Old 07-31-2013, 11:24 AM Thread Starter
Cooneys08JK
Any of you guys heard of faulty mopar oil filters?
post #10 of 10 Old 07-31-2013, 02:01 PM
gogogooch
2009 JK Wrangler
I had an '86 Grand Am that did something similar - turned out one of the fly wheel teeth had sheered, therefore on certain starts it would 'screech' - no idea if these Jeeps have a flywheel or not.
Cowl rust already? 2008 with 27000 miles Dronac JK Wrangler Technical Forum 23 08-12-2010 02:37 PM
2008 JK DEATH WOBBLE 9,500 miles Drummie JK Wrangler Technical Forum 29 11-16-2009 06:44 PM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
Starter bad at 50k miles? thejafe TJ Wrangler Technical Forum 15 08-26-2008 11:15 PM
How many miles on starter? airframer TJ Wrangler Technical Forum 19 08-18-2008 01:30 AM
