2008 JK DEATH WOBBLE 9,500 miles - JeepForum.com
post #1 of 30 Old 08-25-2008, 07:26 PM Thread Starter
Drummie
Driving down highway at 65 when we went over a bridge expansion joint wobble started, then went over next joint and had no control over stearing. Pulled off at next exit called Chrysler. Dealer ship was down the street had problem fixed in 2 hours even though they did not sell jeeps. Mechanic and service manager where great. Both said that the little stock stabilizer was nowhere near what it should have came with. Both front tires scalloped so it has been leaking for a while. jeep is right hand drive too deliver mail i.e. low speed driving. You wouldn't notice anything until you get up to about 55mph. Called jeep and they gave me a government number to call and report problem,that was a little strange to me. Good for you jeep. Working on getting new tires. Anybody else having same problem? CHECK THAT STABILIZER.
Drummie is offline
post #2 of 30 Old 08-25-2008, 07:28 PM
ReBiker
Thanks for the heads up! A lot of people have complained about that on this forum. Hopefully this will help a lot of them.
Window vents, Husky liners, Big Boy horn, Air Vents painted, Mirrors drilled - then relocated, Inside mirror flipped, Hood lift fix, Hitch & wiring installed, Trail cover, Air Cleaner mod, Side Markers / turn signals mod
ReBiker is offline
post #3 of 30 Old 08-25-2008, 07:42 PM
wbower
did i read right that you have a right side drive jk?
Lucky bastar.....
wbower is offline
post #4 of 30 Old 08-25-2008, 08:18 PM
MacK
2015 JK Wrangler
Why is he lucky? I'd drive on the wrong side of the road if I was in a right side JK :P
MacK is offline
post #5 of 30 Old 08-25-2008, 08:24 PM
VegasJeep
VegasJeep's Avatar
id make sure you check your trac bar bolts. This is what the cause of death wobble is from. Many vehicles DO NOT even come with steering stabilizers. All the dealer did was cover the problem not FIX the problem
2001 XJ... 3.5" RE Lift, 31" BFGs, Bilsteins, Defender roof rack, Dana 30 HP front True Trac and 4.10s, Dana 44 Rear True Trac 4.10s, SYE, tom woods D/S, SUPER CLEAN LOW MILES
VegasJeep is offline
post #6 of 30 Old 08-25-2008, 08:49 PM
LHS-Cowboy
DETN8R
LHS-Cowboy's Avatar
my trac bar is perfectly tight and my stabilzer has started to seep. My JK started to wobble at high speeds over bumps about 2 weeks ago. I am getting a new stabilzer. I don't trust a tiny stabilizer made for 32's with a 4 inch lift and 35's... starting to leak at 8000 miles... bad ju ju.
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power
Installed:
R.E. Modified 3.5 Super Flex Kit to 4+/Ft. & Rr. U-joint driveshafts/Full Traction Rear Adj. Trackbar/Custom Ft. Heim Joint Adj. Trackbar/Rancho 9000XL shocks/Yukon 4.88 Gears & Superior Rear Axle Shafts/37" Pitt Bull Rockers on Custom Allied Beadlocks/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Rear Bumper/Custom Trans. Crossmember and Skid/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant HP/Cobra 75 WS XT C.B./Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on Custom Rear Swing Away Carrier/...
____oooo
[ l_,[____],
l---L -[
OlllllllO]
( )_) ( )_)--)_)
LHS-Cowboy is offline
post #7 of 30 Old 08-25-2008, 10:48 PM
thejafe
thejafe's Avatar
This has been covered a million times and I'm sure this topic will continue to surface until Jeeps stop coming with solid front axles.
Truth is that your steering stabilizer is not the cause of, nor the fix for death wobble. Your suspension should (and will) operate normally without any steering stabilizer at all.
thejafe is offline
post #8 of 30 Old 08-25-2008, 11:12 PM
thejafe
thejafe's Avatar
Causes of death wobble:
1) Loose steering components - usually front track bar (be sure to check passenger side)
2) Out of balance wheels/tires
3) Bad alignment
4) A combination of more than one of the above
thejafe is offline
post #9 of 30 Old 08-26-2008, 07:27 AM
91Jeep07
It's not the stabilizer, mine has been to the dealer multiple times, has had the stabilizer replaced, reps & DC Tech's have looked at it, bolts torqued, bushings checked, alignment checked, etc, etc, problem still exists.
What's the possibility of it being the Goodyear Wrangler tires??
91Jeep07 is offline
post #10 of 30 Old 08-26-2008, 08:08 AM
thejafe
thejafe's Avatar
Try swapping in a set of your buddies tires and see if that solves the issue.
thejafe is offline
post #11 of 30 Old 08-26-2008, 09:02 AM
91Jeep07
Search the NHTSA complaint database to see the number of complaints on this issue also:
http://www-odi.nhtsa.dot.gov/complaints/index.cfm
91Jeep07 is offline
post #12 of 30 Old 08-27-2008, 08:31 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
that's what i was thinking. if you have no other places to check, maybe your tires are bad.
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
post #13 of 30 Old 08-28-2008, 11:09 AM
no1martian
2009 JK Wrangler
Shimmy
If you are experiencing shimmy you need to replace you steering damper. It is either damaged or has malfunctioned (i.e losing fluid). In addition you should check the balance on your tires and rebalacne if necessary. You do not need tires you need a new steering damper.
no1martian is offline
post #14 of 30 Old 08-28-2008, 11:23 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
this is the second time i've seen you blatantly post bad information.
USN Hull number 54
Poor Boy is offline
post #15 of 30 Old 08-28-2008, 03:05 PM
91Jeep07
Once again, steering stabilizer replaced, wheels balanced, bolts torqued, bushings checked, ect., etc., etc., problem still exists. The tough part is finding 4 new tires to replace & try. My previous Jeep had BFG AT's & no problem with those.
91Jeep07 is offline
17777 Miles and I've got the dreaded death wobble rollinrubicon TJ Wrangler Technical Forum 52 10-23-2010 08:09 PM
Death wobble - 45,000 miles, no susp work Ole Yeller TJ Wrangler Technical Forum 20 04-20-2009 02:23 PM
Death Wobble showed up, 700 miles from home jjenkins11 TJ Wrangler Technical Forum 7 05-13-2008 10:47 AM
Death Wobble at 50k miles on stock TJ Unlimited TJ Unlimited TJ Wrangler Technical Forum 9 08-21-2007 08:04 PM
Death Wobble at 6200 miles???!! jeeparoo TJ Wrangler Technical Forum 2 08-01-2007 05:03 PM
