2008 jeep wrangler power steering pump - JeepForum.com
post #1 of 3 Old 08-19-2013, 05:46 PM Thread Starter
Aggie35
My power steering went out this weekend while doing donuts. I took off the belt and noticed the power steering pump pulley would slide in and out. IV read that you should need a tool to take it off? I slid it all the way out and it looked like there was threads or something that had broken off inside the pump im just not sure if there is any or what exactly is going on?? thanks
Aggie35 is offline
post #2 of 3 Old 08-19-2013, 09:17 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Welcome to the forum. I would say a small wheel puller is needed to remove the pulley from the shaft. Either way, sounds like you need a new pump.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 3 Old 08-19-2013, 09:31 PM
mello
There is a special puller for a power steering pump pulley. There is also a special tool to install the pulley back on pump. A power steering pump has some in and out shaft play that is normal. If the treads u see are inside the shaft they are there for the installer to screw into.
mello is offline
