2008 Jeep will not start - JeepForum.com
post #1 of 4 Old 09-28-2013, 09:02 PM Thread Starter
MKmyatt
2008 LJ Wrangler
I have a 2008 Wrangler-will not start, starter will not engage.
1)Symptoms-some time ago-(two months)- changed battery in key FOB-had trouble starting for a few minutes then started but remote key locks didnt work again. 2)When doors are locked and the key is used to unlock, the alarm sounds. Today tried cranking
1)Cranked and ran 1-2 seconds. This happened two or three times, Similar to symptoms i had when key FOB battery was changed. Let set for 5 minutes and inserted key upside down, when trying to crank-everything works, but starter never engages.1)Bought diagonstic reader-no fault codes
2)Checked relays-Run, Run Start, Run Accessory come on. Starter relay never turns on. Relay ohmed out fine, never getting power to it. Tried starting in neutral, nothing. pushed hard on shifter in park, nothing. Jumped contacts on strt relay and starter engages and tries to crank. Ran Jumper cables from negative to battery, have not grounded to bell hsn yet. will do tomorrow. Any other ideas?
MKmyatt is offline
post #2 of 4 Old 09-29-2013, 09:18 AM
JIMBOX
How old is the main battery ?
12vdc connectors corroded/tight/clean ?
On IGN, the ECM isn't getting the right voltage for continued ops--
Battery charger/shut EVERYTUING off, try again !
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #3 of 4 Old 09-29-2013, 12:01 PM
Jiblet
Sounds a bit like the sentry key isn't matched. The sentry transponder coding is different than the fob battery functions.
Do you have a second key to try?
Jiblet is offline
post #4 of 4 Old 09-29-2013, 06:44 PM
JTPhoto
JTPhoto's Avatar
Disconnect battery, let stand 10 minutes then try again.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
