2008 factory soft top on 2013 Jeep opinions - JeepForum.com
post #1 of 8 Old 05-05-2013, 07:46 AM Thread Starter
moviehunter
Hi,
A little background... I just ordered a 2 door 2013 wrangler sport from the dealership. Unfortunately the dual top group is not an option in this model (and they wanted an extra $1800 to add the soft top). So I opted to pay the 900$ to get the hard top figuring I could find a gently used/aftermarket soft top cheaper and easier than locating a hard top.
* Now first off, after reading numerous threads on several sites and many contradicting posts, I'm just looking for a little confirmation. A 2008 factory top will fit on a 2013 as long as I get all of the original 2008 hardware (door surrounds, rear tailgate clips, and sport bar attachment brackets, anything else?) correct?
* Secondly, I've read that there are quite a bit of issues with these tops leaking (is this a design flaw for that year or more user error?, did it affect all 2008's?). This top was apparently used for one summer then taken off and the jeep was stolen while the hard top was on it. I can get the top for $350 with all hardware or order a 2013 super top NX for about $850. How does the quality compare? I read that they're the same top but also read that the super top is much more cheaply made. Was the leaking issue really that bad in 08, should I be worried? Are there still leaking issues with the newer tops? Just looking for some opinions on which way I should go.
Thanks, Sean
moviehunter is offline
post #2 of 8 Old 05-05-2013, 08:01 AM
JTPhoto
JTPhoto's Avatar
Leaking was a door seal issue. For 350$ you can't go wrong. Scoop it up quick. If it doesn't work for you sell it and buy a newer version.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #3 of 8 Old 05-05-2013, 08:58 PM
SkipperTW
2016 JK Wrangler
I am fairly certain (but have not seen 1st hand) the 2008 top will only fit up to a 2010 - in 2011 they changed some minimal items that may keep the soft top from fitting on your 2013. But keep looking for a 2012 or 13 top. you should find one for the right price.
SkipperTW is offline
post #4 of 8 Old 05-05-2013, 09:30 PM
JTPhoto
JTPhoto's Avatar
2010 was the change in roof design. As long as you have the appropriate door surrounds 2007 to 2013 will fit.
^^Jeff^^
JTPhoto is offline
post #5 of 8 Old 05-06-2013, 11:46 AM
Morris4x4Center
Morris 4x4 Center
Morris4x4Center's Avatar
1987 YJ Wrangler
Can't go wrong with a brand new Bestop Supertop NX with brand new hardware and all!
[B]
Jeep Parts and Jeep Accessories
(954) 941-7807
We offer Price Match, Military, Law Enforcement & Special Forum Discounting
Plus Free Shipping on Orders Over $75*!
Please PM us for any questions.
Morris4x4Center is offline
post #6 of 8 Old 05-06-2013, 08:33 PM
surfdogs
The 2008-2010 tops require you to to manually pull the top out from the door seals. In 2011 they redesigned it. I put the top down often on my 2008, so when I found a 2011 top for 350 with all the seals, I jumped on it. It saves me an extra walk around the jeep to unfasten the rails. My canvas had a small rip in it, and I couldn't see to pay jeep the 700 for new canvas.
That said, if you are sold on a 2008 top, make sure you have year-correct door surrounds. If you run short on hardware, there's a full 2008 top in my attic.
Also, the 2008 and 2009 tops have a smaller rear window.
surfdogs is offline
post #7 of 8 Old 05-06-2013, 08:43 PM Thread Starter
moviehunter
Thanks for all of the replies. I did pick the top up for now, got it for $300 and figured I couldn't go wrong. I wanted to make sure I had a top for when my jeep comes in. Ideally I'd like to find an unused still in the box 2012-2013 top for under $500. Unfortunately right now there are none, only ones I've found have been for a 4 door. That being said this one supposedly came with all of the hardware (won't be sure until I try installing it) and for 300$ I figure it can be a temporary fix. How much of a pita is it to put these tops down (compared to the 2004 tj I was driving)? And if I run short on hardware I may just have to take you up on that offer surfdog.
post #8 of 8 Old 05-07-2013, 10:14 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Could a marine canvas repair place fix it? You should have a few around you.
JeepCares is offline
