2007 Wrangler Unlimited X - engine issues? - JeepForum.com
post #1 of 4 Old 07-26-2013, 08:32 AM Thread Starter
mswhitman1
I'm a new Jeep Wrangler owner. I had bought a 2007 Wrangler Unlimited X from a wholesaler in Novemer 2011. Not long after buying the Jeep I started having to put money into it - replaced the steering assembly and axle seals, frozen rear calipers, O2 sensors. AC compressor had gone bad, water pump was leaking badly, engine was burning through 5 quarts of oil every couple thousand miles. Mileage was very low - maybe 50k.
Instead of continuing to put money into it, I traded it in with a dealer and bought a similar 2007 Wrangler Unlimited X, just more perks (power everything, etc). Similar mileage (currently 50k). Also bought a warranty to go with it. I've had it for three months and I'm now experiencing similar issues to the last 2007 X I had. Having significant vibrations while driving around 55 - 65 mph. Gas cap indicator and check engine indicator lights are on. Check oil light pops on and off all the time. All the tell-tale signs I had with the last one I'm having with this one.
Has anyone else experienced significant engine issues with their 2007 X? Wondering if there's an issue with the production line or can it possibly be a coincidence that I've owned two 2007's with the same exact issues around the same exact mileage.
Any experiences you could share would be great. Thanks!
mswhitman1 is offline
post #2 of 4 Old 07-26-2013, 10:05 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I am going to say it is a coincidence based on what has been posted on this and other forums for the past 5 or 6 years...there were some engines in 07 and 08 that were assembled in Mexico that had a ring problem, but only a few of those from the ratio of posts. The problems you list are discussed, but not all on one vehicle! Sounds like you got a couple of real lemons and not typical IMO.
Welcome to the forum.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 4 Old 07-26-2013, 03:02 PM Thread Starter
mswhitman1
Thanks Rocky...taking #2 into the dealer this weekend to have it checked out. I like the '07 engine and frame, there's room to work around it, but I'm not handy enough to take it apart on my own (although I'm learning slowly but surely).
post #4 of 4 Old 07-27-2013, 08:33 AM Thread Starter
mswhitman1
Steering damper went bad, which is causing the vibration while driving at higher speeds. I noticed there is a technical service bulletin for the same thing on the '07's. Is this something the dealer should cover or am I out of pocket on that? The leaking oil was the PCV valve. Again...not covered under warranty because it's considered a maintenance part even though the inspection of the part isn't until 60k miles and my jeep only has 50k. Next time, I'll replace it myself.
burning oil , check engine light , o2 sensors , steering column
