2007 Wrangler Bucking Problems - JeepForum.com
post #1 of 7 Old 07-09-2013, 10:54 AM Thread Starter
JYAR
I have a 07 Wrangler, it is my first Jeep and I got it used a couple of weeks ago. It's great and I love it! It's a 6 speed and I'm still getting used to driving a standard and especially on a truck. The only problem I'm noticing is when I'm parking in a parking spot (flat surface) when I turn the Jeep off and have the E-Brake up it starts to buck when i release my feet off the break and clutch. It's only happened in parking lots and not in my driveway because I always back into my driveway and I typically drive into parking spots. When the bucking has happened I have it in first gear, my feet are on the clutch and break and I pull the E-Brake up. I might be doing something wrong cause I'm still getting used to the stick shift and I'm definitely not a pro. Thanks guys for your time and I really appreciate it!
JYAR is offline
post #2 of 7 Old 07-09-2013, 11:10 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
It's a jeep, not a truck. Sounds like you may be letting off the clutch when the motor is still turning over? Try putting it into neutral and then setting the parking brake, and after it has stopped, then in gear if you need to.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 7 Old 07-10-2013, 07:59 AM
RogueStatus
like ^ said, are you leaving it in gear and releasing the clutch while its still running? You can't do that haha... Needs to be in neutral before you can release the clutch.
---- one foot on brake, one on clutch
---- put jeep in neutral with foot still on brake and clutch
---- remove foot from clutch while other foot is on brake still
---- pull e-brake
---- turn jeep off and put it back into gear if you need to
Jeep-less again
RogueStatus is offline
post #4 of 7 Old 07-10-2013, 08:03 AM
brianjw
---- pull e-brake
You don't have to make it complicated. Drive into your spot with the trans in gear. Depress the clutch pedal as your stopping. Turn key off. Release clutch pedal after the engine is stopped.
brianjw is offline
post #5 of 7 Old 07-10-2013, 08:08 AM
RogueStatus
not sure how that was complicated at all? maybe if you can't read english or have a learning deficit but it was the most straight forward and explained process for someone who is learning.
Jeep-less again
post #6 of 7 Old 07-10-2013, 09:07 AM
brianjw
Lol. Ok dick. You don't have to put it in nuetral and let out the clutch to shut it off, just to put it back in gear again after you shut it off. That's what I was getting at. Just leave it in gear with the clutch pedal depressed and turn it off.
brianjw is offline
post #7 of 7 Old 07-11-2013, 11:15 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
It seems to me that the newer jeeps with the electronic throttle take longer to start AND stop. While it's obvious that your letting the clutch out before it's off....it probably isn't you specifically as much as it is your not used to something taking so long to shut down. I've had 6 Jeeps starting with the 95 YJ and none of them take as long to shut down as the JK. Just hold your foot on the clutch a bit longer until you don't hear the engine anymore. Cheers to your first jeep !
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
2007 , bucking , problem , wrangler
