2007 unlimited w/ manual transmission (100,000 miles) keeps popping out of 1st gear? - JeepForum.com
post #1 of 9 Old 01-03-2012, 09:17 AM Thread Starter
Willey
Hello! I just bought a 2WD unlimited with 100,000 miles... everything on it is in excellent condition but for some reason when I start to take off, it pops out of 1st gear?? Every other gear works perfectly otherwise. Also, when it's in neutral, I hear some transmission whirring type noise but if I lightly tough the clutch, it goes away then fades back in a little? The clutch is also really tight feeling pushing it downward compared to my friends jeep (same year and model). Suggestions? Thank you in advance for your assistance!
Willey is offline
post #2 of 9 Old 01-03-2012, 09:26 AM
HOKIES2010
2011 JK Wrangler
Had kind of the same problems on an old K5 Blazer. It was the hydraulic clutch.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #3 of 9 Old 01-03-2012, 10:02 AM
terrahawk
Throw out bearing is worn and the first gear sychro has never been too good on these even when new.
Speed has never killed anyone - suddenly becoming stationary, that's what gets you!
terrahawk is offline
post #4 of 9 Old 01-03-2012, 12:22 PM
duchessvik
terrahawk's right on. Its likely one of two things, the shift boot causing pressure on the stick, or the syncro between gears 1 and 2.
There's a TSB for it:
TSB Title: 21-001-10A 04/20/2010 M/T - Pops Out Of 1st Gear On Acceleration
SYMPTOM/CONDITION:
The transmission pops out of first gear while accelerating The condition may occur intermittently and may be difficult to diagnose.
DIAGNOSIS:
Verify that the shift boot is not causing the issue by ensuring the boot is not binding when in first gear In addition if the customer complains that the transmission pops out of gear in first, third, and fifth, than the shift boot would be most likely the cause for the complaint Refer to the appropriate service information regarding shift boot replacement If the shift boot is not causing the transmission to pop out of first gear, perform the following Repair Procedure...
duchessvik is offline
post #5 of 9 Old 01-03-2012, 03:02 PM Thread Starter
Willey
This is great help everyone! I have an appointment with the dealership on Friday to have the above TSB assessed / diagnose the issue. It occurs 30% of the time which can't be good at all ...
Willey is offline
post #6 of 9 Old 01-03-2012, 03:19 PM
terrahawk
At 100K miles I can guarantee that the throw out bearing is toast.
post #7 of 9 Old 01-03-2012, 04:22 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
I just had my 08 (34K miles) tranny rebuilt for the same problem. They replaced the shift tower, fork, TO bearing, 1,2 & R synchros. Luckily I have a LT PT service contract.
Good luck and let us know.
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #8 of 9 Old 01-04-2012, 08:13 AM Thread Starter
Willey
If I replace the transmission, would that solve all my problems??
Willey is offline
post #9 of 9 Old 01-04-2012, 06:56 PM
jmb6420
jmb6420's Avatar
As long as the replacement tranny doesn't have the same problems. It wouldn't cure the TO bearing, but while the tranny is out, it's simple to install a new TO bearing.
Mike
08 Rubicon
jmb6420 is offline
1st gear , manual , pops out of gear , transmission
Transmission slipping or popping in 4th/5th gear..? sarinalove YJ Wrangler Technical Forum 1 03-13-2011 07:45 PM
New transmission needed at 5800 miles (2010 Unlimited 6-Speed) tomlennon Wrangler General Discussion 17 12-26-2010 04:51 PM
Transmission just replaced...now popping out of first gear. HELP! Ford4Now TJ Wrangler Technical Forum 9 04-06-2007 07:21 PM
99 manual transmission gear oil blueknight44 TJ Wrangler Technical Forum 16 02-16-2007 10:44 PM
Manual Trany Popping out of First Gear!!! TJ TRunner TJ Wrangler Technical Forum 11 06-05-2006 11:10 PM
