2007 tow package - JeepForum.com
post #1 of 19 Old 02-18-2010, 12:48 PM Thread Starter
mudbogger4x4
2007 tow package
Hey guys, quick question. My buddy is looking into buying a 2007 Wrangler. The one he is looking at, has a Dana 44 rear axle, a metal hook where a hitch would be, and a heavy front bumper with a tube going across the grill, and recovery points on the front of the bumper. It also has fog lights running through the bumper.
My question is... is this a stock Jeep with the tow package?
mudbogger4x4 is offline
post #2 of 19 Old 02-18-2010, 01:07 PM
faster_dad
faster_dad's Avatar
The front bumper sounds aftermarket. Unless the prev owner removed the hitch, it should be there if towing pkg. You didn't mention 2dr vs 4dr, but seems I read that all 4dr came w/D44 in 07. Someone more knowledgeable will chime in with more info.
2007 Unlimited X, Jeep Green, Auto/4.10s/Trak-Lok/Tow/2 tops
Stock, but not for long
faster_dad is offline
post #3 of 19 Old 02-18-2010, 01:21 PM
ronjenx
ronjenx's Avatar
If he is interested in towing, he needs to determine if it has 3.73 or 4.10 gears in the axles.
3.21 would not be good for towing.
ronjenx is offline
post #4 of 19 Old 02-18-2010, 01:22 PM
ctown67
I have an 07 2dr. with a towing package. It came with a D44 with 4:10 gears. the hitch is a frame mount with a 4 pin plug.
List of stock parts that have been eviscerated.
power steering pump, tie rod, front left knuckle, horn, weld on rear track bar, rear track bar bracket, both rear fenders, front passenger fender, punctured spare tire, rear bar pins, steering stabilizer shock, front drivers side shock, spare tire carrier.
ctown67 is offline
post #5 of 19 Old 02-18-2010, 01:36 PM Thread Starter
mudbogger4x4
the gearing is the main thing we want to know. It's a 2 door by the way. I know the 07 tow package had the 4.10's, but I don't know the tow package to see it. I can't Jack up the rear and spin the back tire either to figure out the gears and the window sticker does not give a gear ratio.
The hook on the back I don't know if I'd tow with. It looks similar to a ? mark bolted to the frame. No ball hitch or anything like that and it's always open.
The bumper looks "stockish". It's large with 2 D shackles. The foggers are in the center, underneath, but are set in the bumper and back a little. Rock guards are cut into the bumper over the hole that the 2 fogs are set in. A tube (sounds hollow when u knock on it) is bolted on the top running halfway or so up the grill.
post #6 of 19 Old 02-18-2010, 01:55 PM
ronjenx
ronjenx's Avatar
Since you can't jack it up to spin the tire:
Copy the VIN and bring it to the dealer for a build sheet.
ronjenx is offline
post #7 of 19 Old 02-18-2010, 01:57 PM
nwbronco
2014 JK Wrangler
Sounds like the recovery hook on the back. Tow package would have a frame mopunted reciever back there.Front bumper is other than stock. Get the VIN and call your local dealer parts guy. Tell them you just bought it and want the spec sheet for it. He will fax it to you within minutes. Then you can see what it came with.
Bob K.
nwbronco is offline
post #8 of 19 Old 02-18-2010, 01:59 PM
IPB
Bob K.
This man speaks the truth! I did the same thing with mine, 07 with tow package.
Too many toys not enough time....
IPB is offline
post #9 of 19 Old 02-18-2010, 02:02 PM Thread Starter
mudbogger4x4
Let's try this. Toss up some pics of a 2dr 07 towing package that shows me what the stock front bumper and/or the towing hitch looks like. I know the Dana 44 when I see it, so that's not a worry.
Everything looks stock. Fenders, skid guard, wheels, rear bumper, suspension, etc. I'm tempted to say that bumper and hitch are stock but I can't be 100% without comparing them with pics of stock towing package stuff I guess.
Thanks everyone for the help and speedy responses
post #10 of 19 Old 02-18-2010, 02:04 PM Thread Starter
mudbogger4x4
Ok I'll try a dealer. Can I call up any Jeep dealer and get the info from them?
post #11 of 19 Old 02-18-2010, 02:07 PM
nwbronco
2014 JK Wrangler
Yep. Just tell them you just bought the Jeep and you want the build sheet for it. Have a fax number, and you'll see it within minutes. You can stop by and do the same thing. Have the VIN.
Bob
nwbronco is offline
post #12 of 19 Old 02-18-2010, 03:15 PM Thread Starter
mudbogger4x4
Ok. My friend owes me lunch now lol! I drove to the Jeep and copied down the VIN number. Then I drove all the way to a Jeep dealership near me & a mechanic ran the VIN. I still dont know if it's a tow package or not, but it has 4.10 gears and a rear D44. That's all that really matters anyway
thanks everyone!
post #13 of 19 Old 02-18-2010, 08:09 PM
Voyame
An 07 non-Rubicon with 4.10s is likely a factory tow package. That also includes limited slip rear end. At least that is what my package is. And the front bumper wouldn't give you any clues about the rest of it.
Voyame is offline
post #14 of 19 Old 02-18-2010, 08:25 PM
ronjenx
ronjenx's Avatar
A friend of mine bought an '07 (new) with 4.10 axles, no tow package.
ronjenx is offline
post #15 of 19 Old 02-18-2010, 09:14 PM
Ron Burgundy
Team CANON
Ron Burgundy's Avatar
2009 JK Wrangler
Me too. 07 auto. D44. 410s. Rear hook (stnd on sahara). Not tow pkg. 410s rock!!!! Great performance and better mpgs than my buddy's 3.21 geared jeep.
I appreciate all of the info & good people on this site.
JK Sahara 2dr
Ron Burgundy is offline
Tow package? Yes or no?? Willey JK Wrangler Technical Forum 12 03-06-2009 04:07 PM
The Whole Package TedderX_ TJ Wrangler Technical Forum 32 02-18-2009 04:09 PM
Sahara package VS Rubicon package. What do you really get with the Rubi??? badazzelanore JK Wrangler Technical Forum 16 02-18-2009 09:30 AM
2007 4 Door Sahara 26,681.. Any 2007 deal? shine5555 JK Wrangler Technical Forum 13 12-17-2007 02:36 PM
G Package? FLSeaMonkey JK Wrangler Technical Forum 7 11-20-2006 05:39 PM
