#1 | |
2007 Rubicon Dana 44 need additive???
Does the Dana 44 on the rubicons need to have the additive with the oil when you change the diff oil? I cannot remember. I believe it does, but i wanted to make sure.
#2 |
nope, only limited slips do because they need to have the added friction or they wont engage.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights. |
#3 |
Cut and past from my 2007 wrangler service manual.
CHASSIS Component Fluid, Lubricant, or Genuine Part Automatic Transmission MoparŽ ATF+4 Automatic Transmission Fluid Manual Transmission MoparŽ Manual Transmission Lubricant or equivalent (meeting the requirements of DaimlerChrysler Material Standard MS-9224) Transfer Case MoparŽ ATF+4 Automatic Transmission Fluid or equivalent. Axle Differential (Front) MoparŽ Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent. Axle Differential (Rear) 198 RBI (Model 35) and 226 RBI (Model 44) - MoparŽ Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent. For trailer towing, use MoparŽ Synthetic Gear & Axle Lubricant (SAE 75W-140) or equivalent. Models equipped with Trac-Lok require an additive. Brake Master Cylinder MoparŽ DOT 3 Brake Fluid, SAE J1703 should be used. If DOT 3, SAE J1703 brake fluid is not available, then DOT 4 is acceptable. Use only recommended brake fluids. Power Steering Reservoir MoparŽ ATF+4 Automatic Transmission Fluid |
#4 |
oops I added some.... You think it will matter? It is only like 5-7 ounces or so.
#5 |
It will not hurt it!
JK 4 Door Auto, 35" MTKs, River Raider Snorkel, Dana 44 Axles w/410 Gears, Front & Rear E Lockers , TF 2.5" Suspension Lift, BDS 2" BL, 10,000 lbs Front or Rear Winch, To see mods & my Jeep in Action @ http://www.aaof.us/jeep.htm Member of CCJ, White Jeep Club Member #137, CEO of Black Sheep 4x4s http://www.blacksheep4x4s.org Founding Member of Everglades Jeeps & 4x4s, Events Coordinator, Trail Chief & Ramp Master |
#6 |
Get these Valvoline syn... has the friction additive built in.
http://www.valvoline.com/pages/products/product_detail.asp?product=58
2009 JK Rubicon. Auto, Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear; 11,000# Pull-Pal, Uniden 520XL CB with 3' FireStik Whip. Shrockworks Mid-width Front Bumper with Warn 9.5Ti -- Ordered 7/17/2009; Bumper Received 12/4/2009. Visit here to view my wheeling Pics: Moab-4/2006, 5/2008, 4/2009, 5/2011; Ouray-8/2007, Rubicon-9/2008. http://community.webshots.com/user/thunder1strike Last edited by Thunderstrike; 03-27-2009 at 08:53 PM.. |
#7 | ||
Changed the fluid in my Dana 44 I added some of the additive, the parts store pulled up some specs which said I needed to add 4oz or so hopefully it does not hurt anything
05 Jeep Wrangler X .... RIP 07 Jeep Wrangler Unlimited X ...... let the build begin ARMY TEAM MEMBER #4 Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
