2007 jk rear end whine - JeepForum.com
post #1 of 15 Old 06-19-2013, 08:05 AM Thread Starter
johnamc
hi all I have an 07 jk unlimited sahara with 123,000km. I had the transfer case and diff serviced by the dealer at 80,000km. now I am having a whining sound...normally I would think it was the u-joints but after inspection it looks like a "cv" joint on the driveshaft. can I change just this part? is it difficult?
johnamc is offline
post #2 of 15 Old 06-19-2013, 08:21 AM
duneslider
If it is the drive shaft you will have to replace the whole drive shaft, I am not aware of a way to replace that joint.
I see lots of used ones for sale for pretty cheap if you want to stay with a stock unit.
duneslider is offline
post #3 of 15 Old 06-19-2013, 08:49 AM
JIMBOX
Does it whine on acceleration/deceleration or both ??
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 15 Old 06-19-2013, 10:14 AM Thread Starter
johnamc
both someone driving beside me said it was definitely coming from the diff area....I have some grease splatter on the rock shield beside the cv joint at the t-axle.
johnamc is offline
post #5 of 15 Old 06-19-2013, 10:45 AM
JIMBOX
Yeah, sounds like the CV-usually the ring/pinion will start whining on decel, because of low fluid/gear wear, but both ways/w grease splatter at the CV, probably worth the change !
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #6 of 15 Old 06-19-2013, 10:49 AM
ronjenx
ronjenx's Avatar
The cv joint can come apart for inspection.
ronjenx is online now
post #7 of 15 Old 06-19-2013, 11:48 AM Thread Starter
johnamc
my dealer is quoting 900-1400 for the shaft and joint included. this has to be crazy. there must be a better price....any ideas?
johnamc is offline
post #8 of 15 Old 06-19-2013, 11:53 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Even a new double cardon shaft is half that...or as said, watch eBay, used ones show up all the time for 100 bucks or so.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #9 of 15 Old 06-19-2013, 12:42 PM
duneslider
I just saw a stock rear jku shaft on my local classifieds website (like craigslist) for $125. I see them on jk-forum classifieds often too.
post #10 of 15 Old 07-05-2013, 07:54 AM Thread Starter
johnamc
JIMBO
it is more noticeable on deceleration
johnamc is offline
post #11 of 15 Old 07-05-2013, 07:55 AM Thread Starter
johnamc
can I re-grease it?
johnamc is offline
post #12 of 15 Old 07-05-2013, 08:36 AM
xflstl
xflstl's Avatar
2010 JK Wrangler
I have a (in good shape) take off rear Drive shaft, 50.00 you pay shipping.. Contact me.
xflstl is offline
post #13 of 15 Old 07-17-2013, 09:20 AM Thread Starter
johnamc
so guys...water in my diff and a bearing change is the prognosis. the cv shaft still is not a concern, guess i'll keep that for another day
johnamc is offline
post #14 of 15 Old 07-17-2013, 10:23 AM
RockyClymer
RedRock4Wheeler
If you do have water in your diff, then you have been in some real deep water to get into the vent, or the vent came off or your axle seals went out and you got in deep water, any idea?
NRA Life member
post #15 of 15 Old 07-18-2013, 10:02 AM Thread Starter
johnamc
my diff was serviced by the dealer last November. one week later they changed some seals but were not specific. I rolled through winter up here and late in may I was in some mud but nothing that would have covered the diff. even had the fluid checked a month ago when the noise started. so at this stage i'm baffled. I saw the milkshake come out as the cover was pulled off. left axle shim had shifted. so, full bearing overhaul in the diff for $800. think, praying, the gear and crown are ok. mechanic thought my vent was plugged creating condensation.
johnamc is offline
