2007 Battery Cable Connections - JeepForum.com
post #1 of 10 Old 08-10-2013, 01:58 PM Thread Starter
seito107
Hi All -
I'm new to posting on this jeep forum but have searched for quite a while to find where the battery cables go behind the engine. I've located all up to the split where one branch goes to the alternator and the other goes behind the engine. It splits again and I think I've found the driver's side branch, but it is covered by some insulation. My two questions:
1. Where is the passenger side branch (black cable) connected to behind the engine?
2. If I remove the insulation over the driver's side cable (red cable), what is the best way to reattach? It looks like it's held in by staples, but not sure...
I appreciate any assistance. I am fairly new to doing my own repairs, and decided to just buy a new harness from onsalejeepparts.com and just need a bit of help with the above. Thanks for the help!
2007 Jeep Wrangler Unlimited X
seito107 is offline
post #2 of 10 Old 08-10-2013, 02:02 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Help us help you by letting us know what you are trying to accomplish. Welcome to the forum.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 10 Old 08-10-2013, 02:30 PM Thread Starter
seito107
Thanks for the reply. I realize I didn't really get to the point. I am replacing the battery cable harness (part # 560514599AC) and have located all of the connections except 1 behind the engine. Once I locate that and determine how to put the cover back on the other, I will take the old harness off and replace it with the new cable harness I just bought.
Let me know if you need more info.
seito107 is offline
post #4 of 10 Old 08-10-2013, 03:10 PM
RockyClymer
RedRock4Wheeler
That is exactly what needed to know. I do not know the answer but I bet someone on here knows.
NRA Life member
post #5 of 10 Old 08-10-2013, 08:59 PM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
The ground cable goes from the battery negative terminal to behind the engine on the bellhousing (engine ground). There is another cable from the same terminal that goes to front passenger fender(body ground).
Mike
08 Rubicon
"You can't fix stupid" Ron White
ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #6 of 10 Old 08-12-2013, 10:05 AM Thread Starter
seito107
Best way to access?
Thanks for the replies. I'm guessing the best way (or only way) to access is from underneath, correct? I will take a look again to see if I can locate the body ground you mentioned...I think that is the one I haven't found yet.
Also, has anyone removed the cover on the bellhousing? It looks like it uses staples, but can't imagine staples working well on metal....
seito107 is offline
post #7 of 10 Old 08-12-2013, 01:21 PM
jimk403
2009 JK Wrangler
One end of the negative can be found on the rear driver side of the engine. If you crawl under and look up between the exhaust and block, behind a heat shield you should find it. I just bent the heat shield out far enough to get a wrench on the bolt, then bent it back when done.
Just my opinion, yours will differ.
Proud owner of: '09 Rubicon Unlimited, '90 XJ, '88 XJ, '77 J-10
jimk403 is offline
post #8 of 10 Old 08-12-2013, 03:15 PM Thread Starter
seito107
Thanks! I'll try that. Your response (as well as others) have been most helpful.
seito107 is offline
post #9 of 10 Old 08-12-2013, 05:35 PM
duneslider
There are several grounds on the passenger side of the engine right on the block. I honestly don't remember the negative cable from the battery when I replaced my engine. I remember the grounds all on one stud on the block of the engine on the passenger side though.
duneslider is offline
post #10 of 10 Old 08-13-2013, 01:46 PM
jimk403
2009 JK Wrangler
I crawled under the JK today to double check, and sure enough it's on the passenger side of the block. Sorry.
jimk403 is offline
