2 stupid questions - JeepForum.com
post #1 of 17 Old 01-02-2009, 04:14 PM Thread Starter
LuigiROX
2 stupid questions
were is the ingnition coil on the 07 JK
and were are the fuel injectors?
LuigiROX is offline
post #2 of 17 Old 01-02-2009, 06:01 PM Thread Starter
LuigiROX
no one can help me out
LuigiROX is offline
post #3 of 17 Old 01-02-2009, 06:04 PM
fataltherabbit
owners manual.
1990 YJ ,2.5 AX-5 4.10's 4.5'' l 33''hawgs, 2KC's
2 55watt, Custom Bar, Discos. -- An Finally got a Softop!!!!
" I'd Hate to Advocate Drugs, Violence, Guns or Insanity .. but they have always worked for me" - Hunter S. Thompson
Jeep Build - 11,550$
Sunday.Drivers.
fataltherabbit is offline
post #4 of 17 Old 01-02-2009, 06:25 PM Thread Starter
LuigiROX
that helpS
LuigiROX is offline
post #5 of 17 Old 01-02-2009, 06:26 PM Thread Starter
LuigiROX
how about a real answer
LuigiROX is offline
post #6 of 17 Old 01-02-2009, 06:39 PM
DougieFresh
Originally Posted by fataltherabbit View Post
owners manual.
Weird, I looked in my owners manual and didn't find either the coil or the fuel injectors there... I seem to recall they should be under the hood somewhere...
I wish I could be more helpful but it's too damn cold and snowy outside for me to go take a look for you
2008 2dr JK
Mod List (So far)
OME HD Lift with NitroCharger shocks. JKS front and rear adjustable trackbars. 33" Toyo Open Country MT's on 18" XD Rockstars. JKS Quicker Disco's. RockHard 4x4 Oil Pan Skid. Shrockworks Rock Sliders. Woods SS relocation bracket & evap relocation bracket. sPod switch panel. Tuffy Security Cover
-Drive it like you stole it-
DougieFresh is offline
post #7 of 17 Old 01-02-2009, 06:42 PM
Prot
Prot's Avatar
2014 JK Wrangler
It doesn't use a single coil. If recall correctly, there is one coil per cylinder. You should be able to see the injectors pretty readily, screwed into the head with an electrical connector on each. May I ask what is going on that you need this information for a vehicle that is most likely still under warranty?
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #8 of 17 Old 01-02-2009, 06:45 PM
Woodrep
I believe there are 3 modules on the upper driver side of the engine. They should have 2 plug wires coming out of each module for the coils. The injectors should be located right underneath the intake manifold between the bottom of the manifold routes and just above the exhast manifold I believe.
07 JK Unlimited X, Auto, Zone 3" and soon to be wheels and tires
Woodrep is offline
post #9 of 17 Old 01-02-2009, 07:03 PM Thread Starter
LuigiROX
I trying to find a tach signal for a remote start and my vechicle is out of warrnty already have over 40 thousand on it.
I see a black box with the spark plug wires coiming out of it would that be the ign coil?
LuigiROX is offline
post #10 of 17 Old 01-02-2009, 07:06 PM Thread Starter
LuigiROX
Thanks for the replies i will give it a look let you know what i find
LuigiROX is offline
post #11 of 17 Old 01-03-2009, 09:40 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
What year and model is your Jeep? More info might lead to real answers. 2 cents.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #12 of 17 Old 01-03-2009, 11:08 AM Thread Starter
LuigiROX
Well its a JK Sahara 4 door I believe all the JKs have the same engine I don't think this has changed
LuigiROX is offline
post #13 of 17 Old 01-03-2009, 11:14 AM
RockyClymer
RedRock4Wheeler
I would go with woodrep then - each plug has a coil over and is timed, from what I see under my hood, by wires coming from the referenced modules (not sure what they are)...keep us posted, we want to know what you find out.
NRA Life member
post #14 of 17 Old 01-03-2009, 02:26 PM
joe002
LuigiROX - Ignition Coil Pack - the coil pack has the six spark plug wires coming out of it and is located on the Drivers side.
Fuel Injectors - They are connected to the fuel rail that runs down the center of the engine under the top half of the intake manifold. They are hard to see on the Drivers side, but on the Passenger side itís easy to see the one up front. You can also barely see the middle and back ones on the Passengers side.
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #15 of 17 Old 01-04-2009, 09:51 AM Thread Starter
LuigiROX
thank for the help I could hardly see the injectors but found what i needed
LuigiROX is offline
Some Stupid Newbie Questions Sorry!! 01blackws6 YJ Wrangler Technical Forum 9 12-22-2008 07:37 AM
two stupid questions Sh4dowRac3r TJ Wrangler Technical Forum 12 09-24-2007 05:39 PM
2 stupid questions dcfeeiv TJ Wrangler Technical Forum 8 06-24-2007 09:07 AM
stupid questions...please help! ea615sc TJ Wrangler Technical Forum 3 06-05-2006 05:45 PM
A few stupid noob questions. ProfessorCRX TJ Wrangler Technical Forum 4 08-02-2004 11:13 AM
