2" Lift Drive Shaft question - Page 2 - JeepForum.com
post #16 of 23 Old 10-17-2010, 01:29 PM Thread Starter
BlueLesPaul2006
Originally Posted by aristobrat View Post
Bolts right on. The only "issue" I had was that the exhaust in my JK sits a little lower than most at the cross-over part, which caused a rattle. Rock Hard sent me a shim to address that.
does it come with good instructions? pics and all. Im not sure what to remove. I see a cross bar but would not think you should take that off.
OK, then...the hood is not supposed to flop up and down??
Dang, all this time and I thought it was the famous Jeep Wave!! ~bluegrassguitar
BlueLesPaul2006 is offline
post #17 of 23 Old 10-17-2010, 01:44 PM
djkbooth
2010 JK Wrangler
Originally Posted by mikeinminn View Post
I think I read somewhere that there is no difference between the 2 and 4 doors (with regard to this issue)because the driveshaft that causes the trouble is the front one...thus no difference in length or placement. My 2.5" lift didn't cause contact until I corrected the geometry using a trackbar relocation/reinforcement bracket. Then it was only on extreme left droop articulation while discoed.
4 door here with 4 inch no rub at full articulation, I cant see a 2 inch rip the boot
djkbooth is offline
post #18 of 23 Old 10-17-2010, 02:03 PM
aristobrat
2010 JK Wrangler
The included instructions were OK, but this write-up is what I kept referring back to:
Rockhard Oilpan/Combo Skid
Automatic transmission?
aristobrat is offline
post #19 of 23 Old 10-17-2010, 05:58 PM
djkbooth
2010 JK Wrangler
Automatic transmission?[/QUOTE]
Yes 2010 auto rubicon
djkbooth is offline
post #20 of 23 Old 10-17-2010, 06:31 PM
mikeinminn
There is more than one rub issue with the JK front driveshaft. The one that commonly rips the boot is the transmission oil pan. There is a spot that sticks out of the pan and aluminum flange that it attaches to that grabs the boot and the band that holds it on. There is also an issue with the trans skid plate but my 2.5" lift isn't enough to cause trouble. The last is the exhaust pipe. Again, with the exhaust, you'll likely never see a problem until the lift is way more than 2".
mikeinminn is offline
post #21 of 23 Old 10-17-2010, 08:32 PM Thread Starter
BlueLesPaul2006
I guess I will just have to try it out and see what happens. If it rips then I will know. lol
post #22 of 23 Old 10-18-2010, 07:37 AM
mikeinminn
I suspect that you'll be fine....especially with no adjustments to the trackbar.
post #23 of 23 Old 10-18-2010, 07:22 PM
jpg0511
1992 XJ Cherokee
I have been running a Zone 3in for a year and have had no problems with the stock drive shafts in my 2 door auto. And it has seen some tough trails that fully flexed out the suspension. If the boot gets torn then I will worry about replacements.
92 XJ 6 1/2 RC lift plus 2in BB, 35x12.5 Mud Rovers m/ts Aussie front D30 and Powertrax locker C8.25 rear, Rusty HD steering, RC control arm drop brackets, Nates rear bumper, HD SYE, YJ brake lines, Transfer skid plate, Nates slim line front bumper, Smittybilt XRC-8 winch, converted A/C to onboard air, Rino lined Floor boards
06 TJ stock gone
08 JK Rubicon 3in Zone lift, 35x12.5x17KM2s 1.5 wheel spacers, Super Chips programmer
jpg0511 is offline
2" lift , drive shaft , lift , rubbing
ZONE 4" lift??? with stock drive shaft???? sethco JK Wrangler Technical Forum 15 03-11-2009 09:05 PM
what drive shaft should I order for a 6.5" lift mpgrunt2002 YJ Wrangler Technical Forum 2 09-11-2008 09:11 AM
will stock yj drive shaft take 4" lift ???? newjeeper369 YJ Wrangler Technical Forum 9 07-09-2008 09:13 AM
New Drive shaft with 4" lift? JohnnyChimpo YJ Wrangler Technical Forum 5 05-20-2008 09:58 PM
Lift / Drive Shaft Question dman22 TJ Wrangler Technical Forum 1 03-21-2007 06:01 AM
