2" Lift Drive Shaft question - JeepForum.com
post #1 of 23 Old 10-16-2010, 05:54 PM Thread Starter
BlueLesPaul2006
I have a 08 4 door JK X with an auto trans. Im looking at a small 2" lift from Rustys. I don't want anything to high or wild since I will only be doing moderate trail runs. My question is with a 2" lift and 285/70/17s will I need to replace my front DS? I have heard of the boots ripping off when wheeling. I would like to keep the DS stock for now. Im thinking that only 2" will not make that much of a change in the angle of the DS, or am I wrong? Rustys Offroad: JK Wrangler 2" Basic Kit
Any thoughts on this?
OK, then...the hood is not supposed to flop up and down??
Dang, all this time and I thought it was the famous Jeep Wave!! ~bluegrassguitar
BlueLesPaul2006 is offline
post #2 of 23 Old 10-16-2010, 06:22 PM
mikeinminn
I have a 2.5" lift and the DS hit the auto transmission pretty solidly. However, if you don't get an adjustable tackbar to recenter the axle (which is generally considered unnecessary with a 2" lift) you probably won't hit. I didn't have a problem until I recentered. Maybe others have had different experiences? If you don't have to replace the DS, don't. The Rzeppa allows you to lift without having to choose between correct caster and correct driveline angle. With the stock DS you can just install cams (if you want) and set the caster without concerns. AEV is working on a narrow Rzeppa shaft that will be the best of all worlds. Just waiting.....
mikeinminn is offline
post #3 of 23 Old 10-16-2010, 06:26 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Seems to be that the front DS only becomes a problem at 2.5 or over on an auto because of the under body clearance...try it out and see if it works.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 23 Old 10-16-2010, 09:47 PM
djkbooth
2010 JK Wrangler
not on a 4 door
djkbooth is offline
post #5 of 23 Old 10-16-2010, 09:58 PM
mikeinminn
not on a 4 door
I think I read somewhere that there is no difference between the 2 and 4 doors (with regard to this issue)because the driveshaft that causes the trouble is the front one...thus no difference in length or placement. My 2.5" lift didn't cause contact until I corrected the geometry using a trackbar relocation/reinforcement bracket. Then it was only on extreme left droop articulation while discoed.
post #6 of 23 Old 10-17-2010, 05:40 AM
Res6cue
2009 JK Wrangler
I used a Rubicon Express 2" lift & shocks on my JKU 4 door Auto and have had no hitting or rubbing issues so far
Res6cue is offline
post #7 of 23 Old 10-17-2010, 06:51 AM
skivviss
2010 JK Wrangler
in my setup:
2dr auto
3.5 clayton lift
jks quicker disconnects
adjustable trackbars
bilstein shocks
the stock driveshaft rubbed on the auto transmission's skid plate when near full droop. threw on tom woods 1350, but it still contacted slightly at full droop.
i ended up removing the stock transmission skid plate.
still don't know what variable in my set-up wouldn't let a narrower aftermarket drive shaft clear the stock skid.
edit: jimbo raised a good point below that i left out in mine. the full droop where i had continuing problems contacting was not done in the wild. it was in a garage with one wheel taken far farther then i think have the gonads for on a rock.
skivviss is offline
post #8 of 23 Old 10-17-2010, 08:00 AM
JIMBOX
I've got the 2.5" lift on my '08 JKU Rubi (auto) and -no problem
However, I haven't flexed "EXTREME", just off-road, hills/rocks/sand/snow-
By extreme, I mean hanging one tire on the end of the shock!!
I haven't replaced either of the trackbars-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #9 of 23 Old 10-17-2010, 09:47 AM Thread Starter
BlueLesPaul2006
would anyone with a 2-2.5" lift be able to post any pics of the problem area? from the threads that I have searched I cant find many pics of this before damage.
post #10 of 23 Old 10-17-2010, 10:11 AM
aristobrat
2010 JK Wrangler
If you leave your stock automatic trans skid plate on after the lift, you'll likely rip your boot sooner than later.
Ripping the boot isn't a show stopper -- it's not like you'll have to get towed home. IIRC, the boot helps keep the drive shaft lubed. Without it, the DS life is reduced, but some folks have wheeled another 20,000+ miles after the boot ripped before the DS finally gave up.
Who knows when/if you'll need to replace yours. The potential is always there, but personally, it's not something I'd worry about replacing before it fails.
aristobrat is offline
post #11 of 23 Old 10-17-2010, 10:20 AM Thread Starter
BlueLesPaul2006
Can you cut the skid plate down? or replace it for one that will not cut it. I have heard about people notching it, that must be what they are doing it for.
post #12 of 23 Old 10-17-2010, 10:31 AM
aristobrat
2010 JK Wrangler
I think I've seen a writeup where someone "notched it" to help with this issue.
I ended up replacing my stocker trans skid plate with the one from Rock Hard that also covers the oil pan. It doesn't seem to have the same rub issue as the stocker.
post #13 of 23 Old 10-17-2010, 11:12 AM Thread Starter
BlueLesPaul2006
Thanks I looked up the rock hard skid. I think that is what I will put on. does it bolt right on or do you have to modify anything to install?
post #14 of 23 Old 10-17-2010, 11:41 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Here is a thread with pic's of one issue > http://www.jeepforum.com/forum/f96/d...d-off-1049230/
It came directly from the F.A.Q.
Jim
JLC08JK is offline
post #15 of 23 Old 10-17-2010, 12:48 PM
aristobrat
2010 JK Wrangler
Bolts right on. The only "issue" I had was that the exhaust in my JK sits a little lower than most at the cross-over part, which caused a rattle. Rock Hard sent me a shim to address that.
2" lift , drive shaft , lift , rubbing
ZONE 4" lift??? with stock drive shaft???? sethco JK Wrangler Technical Forum 15 03-11-2009 09:05 PM
what drive shaft should I order for a 6.5" lift mpgrunt2002 YJ Wrangler Technical Forum 2 09-11-2008 09:11 AM
will stock yj drive shaft take 4" lift ???? newjeeper369 YJ Wrangler Technical Forum 9 07-09-2008 09:13 AM
New Drive shaft with 4" lift? JohnnyChimpo YJ Wrangler Technical Forum 5 05-20-2008 09:58 PM
Lift / Drive Shaft Question dman22 TJ Wrangler Technical Forum 1 03-21-2007 06:01 AM
