2.5 Teraflex Lift Question - JeepForum.com
post #1 of 8 Old 10-05-2012, 09:16 AM Thread Starter
BrettWithjack
2011 JK Wrangler
Think I'm gunna go with the 2.5 tf coil lift (not the BB). I hear good things about it. And considering I'm not a hardcore rock crawler, I don't plan on using it for more than the weekend trips to the blue/green trails at Rausch Creek. I have a couple questions though...
Here's a link to what I'm thinking about getting...
http://www.teraflex.biz/jk-2-5-lift-kit.html
--It's the 2.5" JK Lift Kit w/Shocks (4 dr)
Also, not sure if this matters but I'm running 33x12.5x15 GY Duratracs on Level 8 Trackers with 3.5" of backspacing.
So yeah here's my concerns...
1) Anyone use this same set up? How's it perform with lots of light off roading?
2) Anything else I should consider? (i.e. driveshafts, steering stabilizer)
3) I'm thinking of just using the shocks the set comes with (9550 I believe), how do they perform? Any substitutes you would recommend?
Any little bit helps, thanks again in advance
BrettWithjack is offline
post #2 of 8 Old 10-05-2012, 09:22 AM
gwar11d2
2009 JK Wrangler
I'm running that kit w/ the 9550 shocks. I ran w/ it for about a year complete how it comes. I recently added AEV control arm brackets to correct caster angle. Some people suggest adjustable lower control arms but the brackets met my budget. Pretty strait forward install. Can't really say anything bad about it and it flexes really nice.
Plenty of pics in the link in my sig. Have fun!
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #3 of 8 Old 10-05-2012, 09:24 AM
KrawlOff-Road
Vendor
KrawlOff-Road's Avatar
It is a nice kit. If you are wanting a nicer shock, you could look at the 5100's from Bilstein. And as Gwar pointed out, you might want to look at doing something sometime to fix the castor in the front. Aside from that, it is a solid lift!
-Jason
Phone: 864-437-8029
Forum Discount: KORJEEPFORUM
KrawlOff-Road is offline
post #4 of 8 Old 10-05-2012, 09:27 AM
Vin
I have that set up with 315/70-17 Duratracs on Mickey Thompson Signature Series Wheels (4.5 inch backspacing) for a little over a year now.
I daily drive 60 miles on the highway, and I find there set up very drivable. I haven't tried any other shocks, but I have no issues with the 9550s. At 33 tires, you should have no problems with the OE drive shafts or stabilizer. I haven't quite as much off roading as I would have liked to, but so far my rig has been performing well.
Vin is offline
post #5 of 8 Old 10-05-2012, 09:33 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I am very happy with my 2.5 and 9550s. The install took all of 8 hrs working by myself. the ride on highway is improved over factory - and off road on the rocks I am pleased (but immediately wished I HAD gone 3.5 lol). I have enough caster (4.2) that I am not worried about the relocate - but its a vehicle to vehicle thing - most likely you will not need. I do plan to put a .75 spacer above it - but at that point I likely WILL need caster correction (and possibly drive shaft) so its way down on my list... may just bite the bullet and go with a complete arms and spring kit. With my experience with TeraFlex - I will probably stay with their products when I do.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #6 of 8 Old 10-05-2012, 11:01 AM Thread Starter
BrettWithjack
2011 JK Wrangler
Thanks for all your input, definitely puts my mind at ease.
Jason, I've always been a fan of RK lifts as well. Can you tell me what all goes into the 2.5 stock mod you guys offer?
Also, any recommendations on a steering stabilizer that works well with the tf or rk lifts? haha do I even need one?
-Thanks
post #7 of 8 Old 10-05-2012, 01:37 PM
TeraFlex
TeraFlex has a nice HD Stabilizer now for Jeeps. #1513001 $56.99 retail. Now you do not have to upgrade your stabilizer to run this kit.
TeraFlex is offline
post #8 of 8 Old 10-06-2012, 08:59 AM
jayrubicon
Just put that bad boy on my wife's JKUX ... Noticeable difference in wander/ wobble. Great SS!
jayrubicon is offline
2.5 , lift , problem , questions , teraflex
