2.5 skyjacker leveling kit questions - JeepForum.com
post #1 of 11 Old 12-16-2012, 02:42 PM Thread Starter
Guns003
I have a 2.5 leveling kit from skyjacker and i was wondering if 35's would fit and not rub. I think im going to do a 1" body kit to make sure nothing rubs. Would that be enough or do i need a whole new lift kit?
Guns003 is offline
post #2 of 11 Old 12-16-2012, 03:59 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
As a newbie, try looking at the FAQ section:
http://www.jeepforum.com/forum/f96/faq-will-rub-610856/
then ask....should help you a lot.
edit - IMNSHO body lifts are not a good idea or needed on a JK.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 11 Old 12-16-2012, 04:01 PM
TheBoss
^^ X2^^ Depends more on your rim offset .Are you running stock or aftermarket rims. A 4.5" offset with 35"tires should be fine on the street. Off road flexed it may rub the fenders if the bumpstops are not adjusted correctly.
TheBoss is offline
post #4 of 11 Old 12-16-2012, 04:15 PM Thread Starter
Guns003
[QUOTE=TheBoss;14620175]^^ X2^^ Depends more on your rim offset .Are you running stock or aftermarket rims. A 4.5" offset with 35"tires should be fine on the street. Off road flexed it may rub the fenders if the bumpstops are not adjusted correctly.[/QUOI
I was going to run 16" pro comp 7031 rim, they have a 4.5 offset and it will be mostly road use. I may how every get xenon flat fenders. A guy has a set on craigslist for 300
Guns003 is offline
post #5 of 11 Old 12-16-2012, 04:22 PM
TheBoss
[quote=Guns003;14620246]
You will be fine with the added flat fenders. Post picts when you get done.
TheBoss is offline
post #6 of 11 Old 12-16-2012, 04:26 PM Thread Starter
Guns003
Ok thanks alot! It may not be soon but when i do it I will defiantly share it.
Guns003 is offline
post #7 of 11 Old 12-17-2012, 09:28 AM
Spike6901
They will rub when you fully flex on the stock fender flare setup. With flat fenders, you are good or with a little trimming and some paint touch up.
But, if you don't wheel then they may never rub.
Future: '17 WK2
Current: '97 ZJ - Lots of mods
Past: CJ-7, XJ, KJ, JKU
Spike6901 is offline
post #8 of 11 Old 12-17-2012, 10:25 AM Thread Starter
Guns003
So if i have a 2.5 lift with 7031 pro comps and 35x13x16 with 4.5 backspacing they wont rub on the road and slight offroad? Sorry just trying o make sure. Want to make my stock fenders last until summer so i can buy new ones over summer.
1995 YJ
35" Procomp MT2s, 5.5 inches of lift, RE 4.5 XD, Bilsteins, MORE body lift, Bumpers,TJ flat fender flares, HD steering, Durango steering box, ZJ 136amp alt, Ford 8.8 Rear, 4.56s
Guns003 is offline
post #9 of 11 Old 12-17-2012, 10:56 AM
Spike6901
Yeah, only when you are fully flexed unless you added some longer bump stop extensions.
These are 33's and you can see that 35's would rub on the back under full flex. I have the same back spacing, stock bump stops, and I can only get a finger between the tire and the fender lip...at most. At least for my setup (see sig), if I want to run 35's then modifications to the fenders would be a must or add bump stop extensions.
Future: '17 WK2
post #10 of 11 Old 12-17-2012, 10:06 PM Thread Starter
Guns003
Will they stick out past my fenders?
1995 YJ
Guns003 is offline
post #11 of 11 Old 12-18-2012, 07:04 AM
Spike6901
Yeah, just little.
Future: '17 WK2
35" tires , lift kit advice , lift kits , rubbing , spacer lift
