2.5 OME lift - JeepForum.com
post #1 of 8 Old 03-18-2010, 09:50 PM Thread Starter
boganza85
2010 JK Wrangler
2.5 OME lift
I'm looking to do a 2.5 inch OME lift on a 2010 wrangler sport. The kits only come with springs and shocks. What else do I need to make the lift a sucess? What size tires would I be able to run with this setup? Thanks.
boganza85 is offline
post #2 of 8 Old 03-18-2010, 10:22 PM
wilywillie
From helping other guys do this (with assorted lifts), I'd get longer swaybar disconnects, and brake line extensions. Longer bump stops, perhaps.
That OME is sweet, just out of my range right now. Fits 33's easy, 35's if you don't hammer it on the trail/rocks.
Tires and wheels are a whole different question. Lots of posts here.....(Someday I'll get 32 1050x15's with a 3.75" backspaced rim. I have 3.21 gears, so that's pushing it)
wilywillie is offline
post #3 of 8 Old 03-18-2010, 10:28 PM Thread Starter
boganza85
2010 JK Wrangler
Sweet thanks, appreciate the info. I figured I would see what the best was and just buy my lift once instead of buying cheap and then upgrading it later.
post #4 of 8 Old 03-18-2010, 11:33 PM
Spokalu
2009 JK Wrangler
OME is sweet. That is what i'm running with their long travel shocks. You will need what wilywillie said and you can fit 35's no problem. Depending on your wheels and backspacing you may have a slight rub on the fender. You can get the brake line drop brackets and not replace the whole brake line if you wish.
Spokalu is offline
post #5 of 8 Old 03-19-2010, 06:26 AM
USAntigoon
Retired from Forum
boganza85
I have a OME lift. In the front the 616 springs with about 3 inch lift. The rear springs are the 617 with about 2" lift. Got the nitro chargers, the JKS adjustable track bar and a set of Teraflex front lower adj. arms. I also got a track bar brace welded on the rear axle.
I upgraded the steering stabilizer to a HD BDS one..
I just love the ride..
USAntigoon is offline
post #6 of 8 Old 03-19-2010, 09:40 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
x2 I love my OME lift and I added JKS adj track bars front and rear and adj CAs to set caster in front and pinion angle in rear. I already had longer swaybar links. I used fence menders to lengthen the front/rear brake lines...good to go and a great ride, better than stock.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #7 of 8 Old 03-19-2010, 10:09 AM
bigdobes
2009 JK Wrangler
I have an OME 2.5 lift on my 4 door Rubicon and just installed 35" GY Duratracks. I flexed the axle to make sure I would have a rubbing issue.
bigdobes is offline
post #8 of 8 Old 03-19-2010, 10:12 AM
09WRANGLER
2009 JK Wrangler
I have the Ome Lift to, its really an amazing lift, ride quality is really good, regarding what you will need really depends on which coils you are getting hd's will give you 3'' and over on a 2 door so you have to start thinking about control arms like mentioned above and also a lot of guys say that the driveshafts might be an issue ... i have the light coils front and the medium rear, gave almost 2.5" all around, I dont plan on getting new heavier bumpers anytime soon so this setup was best for me.... and my driveshaft should be ok from what i've read...
Anyway if you want no more than 2.5" get the light medium coils ( unless you have heavy bumpers ) and like it was said above, I did, longers links rear, disco's front,fence menders for the rear brakelines and front rear jks trackbars.
09 2dr Sahara, OME coil lift w/shocks, F/R Jks trackbar, Solid diff covers F/R, RC disco's, 16" ultrawheel nomad, 33" Duratracs, Body armor rail, Dynomax catback, ...
09WRANGLER is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 05:59 PM
Feel Kinda dumb asking this... Putting my TJ on a Lift (Work Shop Lift) Ludoc TJ Wrangler Technical Forum 7 03-31-2005 10:03 PM
