2.5 AEV Lift Issues on 2012 JKU - JeepForum.com
post #1 of 24 Old 06-02-2012, 10:20 AM Thread Starter
mountainkahn
Okay, so I just installed the 2.5 Dualsport AEV lift yesterday. HAven't yet changed out the tires, so it is still sitting on the stock 17" rims with wranglers on them... So, as I come to a stop, at least on the mountain from about 50mph, it sounds like the tires are rubbing, only when the brakes are engaged and coming to a hard stop. I don't hear it on flat, but slight incline will do it.
Anyone know what might be causing it? I've looked and I don't see any rub marks anywhere, and because I have tons of space under the Jeep now, esp. with the small wheels, I can stick my head in the wheel well. It doesn't happen all the time, but mainly when I come to a hard brake on a slight to higher incline...
Let me know your thoughts!
mountainkahn is offline
post #2 of 24 Old 06-02-2012, 10:21 AM Thread Starter
mountainkahn
... Yes, I also got the geometry brackets...
post #3 of 24 Old 06-02-2012, 11:27 AM
chrpet14587
im not sure if you need the wheel spacers, if you look at the clearance in the rear at the sway bar links and the sway bar itself, it could be the foward motion causing the rear to shift and rub in the rear. I have the 3.5 lift and def need spacers.
If it aint dead kick it, if you kick it and its still alive, there's always a baseball bat!
chrpet14587 is offline
post #4 of 24 Old 06-02-2012, 01:25 PM
mrwhipple
i had to have spacers put on with the 3.5" kit as well. i think they're 1.5".
silver jkur
mrwhipple is offline
post #5 of 24 Old 06-02-2012, 07:54 PM
TheBoss
Check to see if you are rubbing on the rear swaybar .
TheBoss is offline
post #6 of 24 Old 06-02-2012, 07:59 PM
muttytruckster
Also I though the front geometry bracket s were not needed on the 2.5.
2007 Jeep Wrangler Unlimited Rubicon -JKUR
Rescue Green 6-Spd, 33" KM2s- 17 x 8 BlackRock Series 909 wheels, Stainless Steel Gibson Exhaust & AFE Air Intake, Superchips, Aberle Front Bumper&10.5K Winch, PiAA ATP Lights
muttytruckster is offline
post #7 of 24 Old 06-02-2012, 08:01 PM
RockHard07
i am assuming that the 2012's are the same setup underneath as my 2007. stock rims do not have enough of an offset to clear longer rear sway bar links. my bet is thats where you are hearing the rubbing from. 3 solutions- buy wheel spacers, buy new rims, or take off your rear sway bar end links until you can purchase one of the above mentioned options. personally i am not a huge fan of the third option on a coil suspension but i hear alot of guys do it just be a little more cautious in the corners.
cross threading is as good as locktite!
RockHard07 is offline
post #8 of 24 Old 06-02-2012, 08:09 PM
TheBoss
They come drilled for 2.5 ,3.5 ,and 4.5. I used them on my 2.5 lift and had to use a ratchet strap to pull the axle back to line the holes up. That alone led me to believe they were needed.
TheBoss is offline
post #9 of 24 Old 06-02-2012, 11:53 PM Thread Starter
mountainkahn
Well, I looked all over and haven't found any evidence of rubbing. I haven't checked the rear, however, though the sound is located near the front. I will check in the morning and update - But, I think spacers might help.
As for the brackets, it isn't needed, but it returns everything to the stock geometry. I am trying to reduce the risk of speed wobbles, as I've had them before. My offroading needs are minimal - simple ungrated fire roads and bush whacking to get to rocks for climbing amd/or hunting, so the complaints about them getting in the way for the 2.5 I don't anticipate having an issue. Not a rock crawler at all...
post #10 of 24 Old 06-03-2012, 06:37 AM
TheBoss
If you are using the stock bumper look at the front lower air dam. Since you think it's comming from the front.
I looked under mine ,granted I'm running an offset wheel but I don't see anything in the front that could rub. Maybe your brakeline if it isn't tied back enough.
TheBoss is offline
post #11 of 24 Old 06-03-2012, 10:07 AM
aristobrat
2010 JK Wrangler
It seems to be hit or miss with 2.5" lifts.
When I ran a TF 2.5" lift, the change in caster (to me) was definitely noticeable -- my JK was flighty at higher speeds. Any faster than 60mph required two hands firmly on the steering wheel at all times and even then, it still felt like you might drift into another lane.
Others with the same lift didn't experience that.
aristobrat is offline
post #12 of 24 Old 06-03-2012, 11:22 PM Thread Starter
mountainkahn
I looked all around and it doesn't seem that there is any way the tire can be rubbing. I find that it is only when there is some compression, in other words braking hard causing the front end to dip, or going over a low area hard to cause the shocks to compress -- I hope you get the idea.
The only possibility is the brake lines. I tried to move them out of the way, and it still does it in the above circumstances. I will recheck the instructions and see what I Can find.
Anyone with the 2.5 AEV lift have this problem on a 2012?
post #13 of 24 Old 06-04-2012, 06:13 AM
gwar11d2
2009 JK Wrangler
2012, Exhaust hitting someplace? I thought you needed to do something w/ the exhaust (use spacers, etc) on the 2012's...
although you may have done this...if you have disregard. Other than that it could be the need for wheel spacers.
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #14 of 24 Old 06-04-2012, 06:19 AM
paul84043
Well, I take this as one more vote for my RK 2.5" lift.... Stock wheels and tires and you're having issues??? Why would spacers be needed to run stock?
And that being said...spacers here in Utah are illegal, so what do you do then?
I can see with the 3.5" kit maybe, but the 2.5? I seem to recall another thread a few months back complaining about AEV's 2.5" kit, can't remember the exact issue though.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #15 of 24 Old 06-04-2012, 06:46 AM
gills
I have the AEV 2.5" with drop brackets, stock 18" Sahara rims & tires and NO issues.
I did read elsewhere about someone who had a shop install his lift, and they hadn't torqued the control arms properly, which led to noise issues.
Have you gone through and double-checked torque on every bolt that was involved?
2007 Sahara - Rescue Green, 2-Door, 6-spd, 4.10 gears & dual tops. AEV 2.5" lift, hood, drop brackets, snorkel & rear slider. Cobra 75 WX XT CB, Mastercraft Grab Handles, Rugged Ridge light bar, hydraulic hood struts, T&T Customs Adventure Series sliders & IPF 968 lights.
Waiting to be installed: River Raider breather extension, and not much else for this year...
gills is offline
Manual Tranny Issues new 2012 JK Compgod JK Wrangler Technical Forum 31 04-19-2012 03:00 PM
2012 JKRU & JKS Front Trackbar & Sector Shaft Reinforcement Kit Issues bdmckenna JK Wrangler Technical Forum 0 04-08-2012 01:14 PM
Another guy asking about mileage, issues, etc with the 2012 sport unlmtd Chazz11bravo JK Wrangler Technical Forum 12 03-22-2012 12:48 PM
430n garmin 2012 issues Vanne JK Wrangler Technical Forum 3 02-06-2012 07:55 AM
anyone having some issues with the 2012? garettt520 JK Wrangler Technical Forum 3 11-28-2011 06:05 PM
