1997 TJ clutch vs. 2013 JK - JeepForum.com
post #1 of 30 Old 09-05-2013, 08:25 AM Thread Starter
mummaG_207
Disclaimer: I am not technical but learning
The clutch in my new JK (2013 6 speed manual 3.21 ratio) is totally different than my 1997 TJ 4 speed manual (bought used)
Does anyone know why? Is it b/c it's new? or something has technically changed between the models?
thoughts helpful as I feel like I'm learning to drive a clutch all over again. took it off road yesterday and stalled a ton of times as I learn to climb hills again (in 4WD 4 hi and out of it)
Thanks!
mummaG_207 is offline
post #2 of 30 Old 09-05-2013, 11:52 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
What do you mean by different? The JK is a hydraulic clutch, was the TJ cable?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 30 Old 09-05-2013, 11:54 AM Thread Starter
mummaG_207
That might be my answer. I seem to struggle with feathering the clutch and it seems more sensitive than the tj.
post #4 of 30 Old 09-05-2013, 11:57 AM Thread Starter
mummaG_207
I'll start to educate myself on hydraulic vs cable.
post #5 of 30 Old 09-05-2013, 12:56 PM
awinski
It may be the hydraulic clutch plus fly by wire throttle, it may be the rather low 3.21 gears compared to maybe a 3.73 in your last jeep (last jeep may have had 3.21s also), also many have stated the 3.6l having a different clutch compared to past jeeps. Id say it reminds me more of a cars rather than truck.
All in all hope you re learn quickly
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #6 of 30 Old 09-05-2013, 01:29 PM
dciman
Both have hydro clutches.
Your TJ clutch was probably worn a bit and the new JK is likely feels really grabby. You just need some time on it.
dciman is offline
post #7 of 30 Old 09-05-2013, 01:43 PM
horaceunit
I am dealing with the same thing. My TJ was a 4 banger and had the 4.10 gears and the new sport has 3.21's and I think that makes some difference. My only real issue with the JK is 1st gear, I seem to want to let out the clutch too fast without enough gas pedal and have stalled it a couple of times in the past 3 weeks. My TJ seemed a bit more forgiving as far as the clutch was concerned. On the TJ, however, I had to be going slowly enough to downshift from 3rd to second (hardest gear to downshift to was 2nd) and then from 2nd to 1st. With the JK I can go from any higher gear directly to first with no problem or resistence. I also don't seem as inclined to downshift and use the clutch for braking which I did with the TJ as a matter of course. On the other hand I did a full brake job on the TJ and had to pretty much compeletly rebuild the rear drums so I think I was protective of those darn drum brakes!
From an old Navy Senior Chief when I called him sir- "Son, don't call me SIR! I knew who my Father was!"
horaceunit is offline
post #8 of 30 Old 09-05-2013, 04:09 PM
pismo61
pismo61's Avatar
2015 JK Wrangler
Its the drive by wire.Youll get used to it in time.
2015 Red 2 Door(half) 6sp.
pismo61 is offline
post #9 of 30 Old 09-06-2013, 11:03 AM
HOKIES2010
2011 JK Wrangler
TJ hydraulic for sure. Broke one at a drive thru. Guess I didn't need the chicken nuggets after all.
Have a TJ and a JKU, drive them both frequently. The drive by wire is definitely different but the clutch and engage point feels different as well. You do get used to it though.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #10 of 30 Old 09-06-2013, 01:57 PM
horaceunit
Hopefully both me and the OP will get used to it in time! It is a lot smoother shifting I know that!
post #11 of 30 Old 09-07-2013, 06:09 AM
wilywillie
There are also "flash" programmers available to make the throttle response more immediate.
On my 2008, I've tweaked the "wire" to a more responsive setting (Flashpaq), along with tire size/pressure and driving style.
Just a thought...
I'm just here for the gasoline. --Max
wilywillie is offline
post #12 of 30 Old 09-07-2013, 09:38 AM Thread Starter
mummaG_207
New to this......
Flash?
post #13 of 30 Old 09-08-2013, 11:18 AM
wilywillie
There are several brands of little computer-type boxes you can connect (Flashpaq, pro-cal, Diablo, etc), that override stock settings (since everything is computer driven). I have my speedometer gauged to bigger than stock tires, for example. (they're detached when you're done)
post #14 of 30 Old 09-08-2013, 02:18 PM
COStrider
True but the JK clutch has barely any "feel" at all. That's the issue that is most problematic in learning the clutch on these babies. I stall mine all the time. Partly because I need to re-gear, partly just operator error. Lol
COStrider is offline
post #15 of 30 Old 09-08-2013, 04:25 PM
AZBob
I didn't like the clutch engagement on a new JK test drive last year. I'm sure I could have adjusted to it but it nevertheless seemed inferior to my 03. There was certainly no such "adjustment" period getting used to the 03. It was comfortable from the very first drive.
A 97 TJ would have been a 5 speed originally. I wonder how yours got a 4 speed, and where it came from?
AZBob is offline
