1997 Jeep Wrangler Starting Problem - JeepForum.com
post #1 of 4 Old 09-24-2013, 10:46 AM Thread Starter
kacetheace
Hello All,
I have done a search of the forum's and on google, and that is what lead me to where I am.
1997 Jeep Wrangler, 4cyl.
While attempting to start my jeep it makes a noise (best described as a low hum), around the back seat area on the bottom. However nothing turns sputters or cranks over.
I then checked the battery and it was good. Lights still work, windshield wipers and radio.
Next I replaced the starter. Still nothing. However after doing some research I can get my jeep to run by way of screw driver touching the two points on the starter.
Further research revealed that a common problem is the clutch safety switch. I bypassed this. The next usual suspect was the ignition. I have replaced the ignition switch, and to make sure it wasn't the cylinder I used a screw driver in the new ignition switch with the same results.
I have prior to this given the jeep a full tune up around 3k miles ago.
Any help will be appreciated!
kacetheace is offline
post #2 of 4 Old 09-24-2013, 11:13 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Wrong forum, try the proper forum and you might get more help....
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 4 Old 09-24-2013, 11:24 AM Thread Starter
kacetheace
Okay, sorry. I am new to this.
post #4 of 4 Old 09-24-2013, 12:05 PM
robplumm
TJ Forum...
But a hum behind the back seat would make me think fuel pump...
robplumm is offline
ignition , starter , starting problems
