18" Sahara wheel and 35" tire? - JeepForum.com
post #1 of 4 Old 11-15-2006, 07:48 AM Thread Starter
Mr. Tarmac
I'm wondering if a 35x12.5x18 will fit on the optional 7.5" wide 18" Sahara wheel. Any thoughts? Seems the 7.5" width would be too narrow. If it would work, it would be nice to be able to use that wheel, add a set of Spidertrax spacers and run 35's.
Mr. Tarmac is offline
post #2 of 4 Old 11-17-2006, 03:39 PM
momomike3
It should be fine. Someone in the TJ side does 35x12.5 on a 7" rim. It's better to be on the thinner side of the spectrum because it holds the bead better. (But tire shops will probably give you trouble about it... I had trouble with 15x8 and a 12.5" wide tire.)
momomike3 is offline
post #3 of 4 Old 11-17-2006, 04:51 PM
FzyPchz
It should fit, but it would probably be best (at least safest IMO) to follow the tire manufacturer's suggested rim size.
FzyPchz is offline
post #4 of 4 Old 11-17-2006, 07:45 PM
UTAH
UTAH's Avatar
It helps protect the rims to "overtire." Just ensure you've got a tough sidewall to take the hits.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
Another wheel and tire size question? (Will 32" tires fit with 2" lift) TJ's02TJ TJ Wrangler Technical Forum 12 10-30-2009 08:43 PM
7" stock wheel and 31" spare tire govols TJ Wrangler Technical Forum 7 06-21-2007 09:11 AM
17" to 16" stock tire/wheel swap doug davis JK Wrangler Technical Forum 4 06-08-2007 02:31 AM
tire options for "X" 15 inch wheel Tortho JK Wrangler Technical Forum 3 11-24-2006 06:23 AM
Largest Tire on a Rubicon "Moab" Wheel? SteelBlueTJ TJ Wrangler Technical Forum 3 12-23-2004 05:46 PM
