16w cube leds into stock fog harness... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 16w cube leds into stock fog harness...
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 04-04-2015, 01:21 AM   #1
takeitsleazy
These lights have become the bane of my existence over the past few months. The original wiring harness failed me somehow, after 6 months. Because the fuse kept blowing I assumed it was a short, but a visual inspection showed me nothing. (theres a thread somewhere) I gave up on the entire harness, thinking it would be easier to wire into the stock fog harness.
I ended up clipping the stock harness end and tying the wires in. black to black, red to white. this is before the blue wire is spliced in. it still doesnt work, and all threads ive seen are no help, because i understand none of them. what am i still doing wrong? 16w is definitely under the 55w canbus limit... ill try to get a pic up but im at my wits end with this ****
USAF RHS
takeitsleazy is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 10:46 AM   #2
02 Grand
2015 JK Wrangler
Don't know specifically what's going wrong, but I think you could save yourself a lot of frustration with a $20 relay kit. The fog circuit would just be powering the relay and the lights would get power direct from the battery. That takes all the weak point out of the mix.
Now: '15 JKU Rubi
In the past: 05 WK, 02 WJ, 11 JKU
02 Grand is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 11:20 AM   #3
SoK66
2009 JK Wrangler
Nothing magic about this. Confirm you have power & ground at the stock harness wires, mark or note which is which. Then confirm sane on the LED. Match pos to pos, Neg to neg. Beaus to solder & heat shrink the individual wires, then protect the harness with conduit. Be sure to match the fuse rating with the LED manufacturers recommendation, not the factory fog light rating. If it's still blowing fuses you have a short or arc somewhere.
Driver has no money. Owns two Jeeps.
SoK66 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 11:26 AM   #4
14Sport
2014 JK Wrangler
The stock fog lights are CANBUS wires. Some guys have been successful with tapping the power to control a relay. But some still get flickering. I, personally, would not tap into a CANBUS wire. For the very reason you're experiencing. And LEDs are directional, hook them up backward and nada. Afterall, they are diodes.
2014 JK Sport, auto, 35x12.5x17, 3.73s, BR6 BBK.
I jeep therefore I am.
14Sport is offline   Reply With Quote Quick reply to this message
Unread 04-06-2015, 04:22 PM   #5
JLH
2015 JK Wrangler
The black wire on most LEDs is the +12V lead wire and white is ground. It would have been nice if the LED light industry followed the red =12V and black = ground.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
JLH is offline   Reply With Quote Quick reply to this message
