15" Alloy Rims W/ 35" tires on Lifted 2 Door (JK) Jeep Wrangler - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 15" Alloy Rims W/ 35" tires on Lifted 2 Door (JK) Jeep Wrangler
Rampage Bowless Soft Top Oconee offroadAlloy USA Still AvailableAdvance Adapters SYE Kits
Unread 10-21-2014, 02:05 PM   #1
STEVEH003
So heres my situation. When I bought my Jeep the aftermarket tires were 33" Toyo Open Country A/T (The originals) with 18" Rims (Makes no sense, Right?) Even though the Jeep is a rough ride I still like everything else about it. Since purchasing it I have installed a 2.5" Rubicon Express lift kit. Now I am looking to upgrade the tires and wheels.
I am moving to Denver in a month so I need a good all-terrain tire.
I am looking at the BFG 35x12.50x15
15x8 or 15x10 Level 8 Tracker Alloy full matte black wheels (not sure which wheel size would be better) (Also which backspacing would be most preferable. I don't want it to sit too wide, but also need to avoid rubbing. I think they offere anywhere between 3.75"-4.5")
I have heard that these wheels will clear the calipers. Is that correct?
2nd question. A lot of tire places recommended a 17" wheel for me, but that would put me into a D or E rated tire which I am afraid of having the same issues I am having right now with a rough ride. I wouldn't mind a 17" wheel If I could find a C rated tire (If they even exist) or a low rated D tire. Anybody have any prior experience with a 2 door jeep on 17" wheels and 35" tires?
Thanks for all the help.
STEVEH003 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 02:36 PM   #2
duneslider
There are probably more people with 17" wheels and 35" tires than anything else on JK's. Air pressure is where it is at though. I run 25 right now, most run it way to high.
I currently have Level 8 trackers (not positive on the backspacing but mine are 15x8) on my JKU with 35"BFG KM2's.
My opinion about BFG AT's is they are the worst all terrain I have ever owned. Some like them but I thought they were poor in every condition.
I have like duratracs, terragrapplers, Toyo's just to name a few. The flaken gets good reviews.
duneslider is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 03:08 PM   #3
222Doc
if you go with a 15 rim you really need 3.75 back space. No matter what width you go with be it 8 or 10. i would not run a 10" rim for a 35 on a 15 for off road. On a 8" you can run them at least at 8 pounds, no bead locks. Rather good side wall to tire ratio. like a 37 on 17.
Yep they do stick out more. You are 1.5" wider than a jk on 4.5BS say on 17x9 35x12.5x17. 4.5" wider than stock. The good thing about 15" is the price of the tire up to 35. My last set were 195$ each for MTRKs 35x12.5x15 . Going bigger you might as well run 17" as the price evens out 37. I would not spend much on 15"s rims. especially if going wheeling. I paid like 45$ each for the steel ones i have had on or JKR. 5 were the cost of 1 good alloy. i run 27 psi street.
you see here were the rims is very close to the tie rod, those are Synergy one's
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 04:48 PM   #4
STEVEH003
Any recommendations for a good 35" D Rated tire for a 17" wheel, that will make the ride smooth on my 2 door. This is where I am having the most difficulty, because i do not want to end up in the same situation I am having with my E rated Toyo tire and having terrible ride quality.
Unread 10-21-2014, 04:49 PM   #5
STEVEH003
Sorry and in an all-terrain tire.
Unread 10-21-2014, 09:28 PM   #6
duneslider
Goodyear wrangler duratracs load range D, They are close to a 35". My 35" BFG's are only barely over 34".
Falken Rocky Mountain ATS load range D
Cooper Discoverer ST Maxx load range D
All good tires. Lots of other ones out there I am sure.
Unread 10-22-2014, 07:25 AM   #7
SLADE
Nitto Terra Grappler LT325/70R17 is a D load rated.
You could also look at tires like Goodyear Duratrac and Fierce Attitude that are a little rougher than a typical AT tire but not as aggressive as an MT tire.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 02:15 AM   #8
zjilla
zjilla's Avatar
15" 3.75 Backspaced MB wheels will definatley clear the caliper.
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
www.annirlane.blogspot.com
October 2013 JK of the month
My Slowly but surely JK build thread:
http://www.jeepforum.com/forum/f96/s...hread-1562595/
zjilla is offline   Reply With Quote Quick reply to this message
