14 Sahara unlimited - JeepForum.com
post #1 of 11 Old 10-10-2013, 05:42 PM Thread Starter
physiosurf
14 Sahara unlimited
Looking to put 20x12 fuel wheels with 33inch toyo
2 inch BDS lift kit, fox stabilizer kit , dirt logic shocks .
Wanting to keep the ride as BEST as possible . Will not be doing any off road , just city, highway. Was told best way to go , anyone know better set up? Was told this will be better than stock ?
physiosurf is offline
post #2 of 11 Old 10-10-2013, 05:57 PM
ROCKR8R
Scrap the steering stabilizer. Your Jeep is brand new so the OEM steering stabilizer is up to the task. Also scrap the Dirtlogic shocks. Who are you getting your info from?
Personally I wouldn't put 20's on either but it is your Jeep. Suggestions: Fox shocks, OEM stabilizer, 15 or 16" wheels with 33's, Rock Krawler 2.5" Max Travel.
-Dan
ROCKR8R is offline
post #3 of 11 Old 10-10-2013, 05:58 PM
JIMBOX
"WOW"--20x12 and 33" tires-
Can't wait to see that, whatcha gonna chrome ??
Hardtop /fenders same color ?--which is ??
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 11 Old 10-10-2013, 05:58 PM
Psycho-X-Jeep
2009 JK Wrangler
Swap the front solid axle for IFS??
Call me Eddo
09 JKUR
13 WK2 Trailhawk
Psycho-X-Jeep is offline
post #5 of 11 Old 10-10-2013, 07:44 PM
JoonHoss
2011 JK Wrangler
If you want it to ride nicely, skip the 20's and stay at 18's max (prefer 17's), the more sidewall, the better the ride.
and do not go with a 12" WIDE RIM (especially on a 33" tire); unnecessary, and looks lame
I love my 2" BDS coil lift, but if you want a soft ride, go with the stock coils and coil spring spacers (budget boost)
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #6 of 11 Old 10-10-2013, 07:54 PM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
There is a Street Jeep section in the General Technical Discussion forum. You should be able to find some help there.
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #7 of 11 Old 10-10-2013, 08:14 PM
brianjw
A Prius might ride nice.
Most of us buy a wrangler for off road capabilities. Buying a solid axle rig, lifting it, running 20" wheels and looking for the nicest street ride is sort of a foreign idea for most of us.
brianjw is offline
post #8 of 11 Old 10-10-2013, 11:35 PM
HappyTrails
HappyTrails's Avatar
What brianjw said.
Honestly, to get the best street ride:
15" or 16" wheels (more sidewall remaining on the tire, the better....more cushion), Rancho 9000 adjustable shocks (very soft if you want them to be), 33"/35" tires, can do 37's with flat fenders & 2.5" lift), stock steering stabilizer (save some money), and a 2.5" COIL lift kit (skip the budget boost ones).
The 20" wheels may look cool on for the street scene, but you will HATE the ride. Too little tire sidewall.
Rule of thumb: Wheel size should be approximately half of the tire diameter. i.e. 35" tire...run 17" wheels, etc.
I run 37's on 17" wheels, and tire pressure about 27psi. Good enough for the highway, soft enough for off-road.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #9 of 11 Old 10-11-2013, 09:10 AM
panthermark
Keep is stock wheels and shocks (no lift) for a nice ride....the engineers knew what they were doing.
(From another Sahara owner)
Jeep - It's a Jeep thing...you wouldn't understand.
Triumph - Go your own way.
I see why I'm a loner....and I love it!
panthermark is offline
post #10 of 11 Old 10-11-2013, 12:46 PM
brianjw
Well that's debatable when you start looking at the improperly sized, non shouldered bolts, pushed through square holes in the flimsy suspension mounts. Lol
But yeah, anyway, stock will ride best. You could use simple spacers, but the axles will be offset. Problem with the bigger wheels, you're now stressing weak factory suspension components and steering components (ball joints etc) by using less backspacing. The stock parts don't hold up that way to bigger and heavier wheels and tires. And the ride is going to suffer on 20" wheels. May be fine for a while, but in a couple months or maybe years, you'll be looking for solutions to sloppy handling, death wobble etc.
I would keep lift height to a minimum. Run 285s or something on aev wheels that aren't going to push the tires out as far. Just an idea. Something with IFS is better suited to what you want, modifying the wrangler becomes quite expensive to maintain good handling qualities with bigger tires and stuff.
brianjw is offline
post #11 of 11 Old 12-02-2013, 02:39 AM
johnrussi
Coil Spacers plays important role in vehicles engine and their parts.
johnrussi is offline
