'14 Rubicon check engine light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > '14 Rubicon check engine light
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-19-2015, 07:52 PM   #1
justals
13k miles and the ck engine light has come on twice now, #5 cylinder misfire. Dealership cleared it both times they said needed updated software and/or new valve cover (service bulletin). Anyone hear of this?
justals is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 09:16 PM   #2
222Doc
222Doc's Avatar
Did they fix the issue or has it returned?
I have not seen a post of this issue since the 012-13 bad heads, many threads on that. jeep even extended warranties on the left heads. Though yours is the right bank.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 09:56 PM   #3
justals
Did not know if problems on the prior models. 14 got the new engine.
Unread 01-20-2015, 05:22 PM   #4
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I did not know the 14 engine was different than 12/13? Just curious about this. I know the 12/13 heads (and thus manifolds) had issues on the left side. Was this somehow corrected in later versions? Just trying to increase my knowledge base...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 01-20-2015, 05:39 PM   #5
justals
Was told Engine went from 3.8 to a 3.6
Unread 01-20-2015, 06:20 PM   #6
mrwhipple
3.6 started with the '12s.
silver jkur
mrwhipple is online now   Reply With Quote Quick reply to this message
Unread 01-20-2015, 07:51 PM   #7
justals
Thanks. So assume it is the same issue on the 14 as was on the 12/13
Unread 01-20-2015, 09:05 PM   #8
mrwhipple
Not sure. I haven't heard of that issue past the '12 - '13 model years. The head that was replaced was on the drivers side.
silver jkur
Unread 01-20-2015, 09:11 PM   #9
justals
Got appointment at dealership on 2/2. We'll see what they say.
