14 bolt and HP dana 60 in a JK - Page 8 - JeepForum.com
post #106 of 187 Old 07-25-2013, 05:24 PM Thread Starter
Dr.Dirty
Well got the tie rod done up today. I wanted to have the Tierod on top of the knuckles but there are clearance issues with the track bar bracket. The pass side will get double sheared with a high steer arm.
diff cover clearance at full lock.
Dr.Dirty is offline
post #107 of 187 Old 07-29-2013, 08:59 AM Thread Starter
Dr.Dirty
Got all my hubs and rotors back form machining. Thanks JP5 for the awesome work. Now i can run the 6 on 5.5 wheels.
The new rotors are from a tacoma so an additional steel spacer had to be machined to make up the offset.
Dr.Dirty is offline
post #108 of 187 Old 07-29-2013, 04:08 PM Thread Starter
Dr.Dirty
while all the hubs were at the machine shop I decided to upgrade the studs
Top new longer 14 bolt studs that are now on all 4 corners
Middle Stock 14 bolt stud
Bottom Stock F350 stud
Test fit in the wheel
I had to slightly clearance the new stud to fit now with the smaller bolt pattern
Dr.Dirty is offline
post #109 of 187 Old 08-02-2013, 05:08 PM Thread Starter
Dr.Dirty
Finally got to set her on her own front feet.
Now to tear the axle back out and do the gears
Dr.Dirty is offline
post #110 of 187 Old 08-02-2013, 05:58 PM
takeitsleazy
subbed. so far over my head but i cant stop reading
2013 JK 2DR 3.6L, 1991 XJ 4DR 4.0L, Wife:2008 JK 4DR 3.8L
takeitsleazy is offline
post #111 of 187 Old 08-02-2013, 07:04 PM Thread Starter
Dr.Dirty
Need to com up a bit in the back
looks like it will be close if i outboard the coilovers. So I might run a 1/2 spacer and that will give me a bit more clearance as well as almost perfectly match the front track width.
Dr.Dirty is offline
post #112 of 187 Old 08-02-2013, 07:09 PM
tyvanwie
Looks sweet.
tyvanwie is offline
post #113 of 187 Old 08-03-2013, 01:07 PM Thread Starter
Dr.Dirty
Got the front sway bar done. need to now work on the bump pads
Dr.Dirty is offline
post #114 of 187 Old 08-05-2013, 12:59 PM Thread Starter
Dr.Dirty
Hi Steer arms are on order..... These will elminate the kingpin springs as well as double shear my steering
http://www.fourwheelsupply.net/produ...kle-tie-in-kit
Dr.Dirty is offline
post #115 of 187 Old 08-07-2013, 04:07 PM Thread Starter
Dr.Dirty
steering arms made it
Dr.Dirty is offline
post #116 of 187 Old 08-12-2013, 03:43 PM Thread Starter
Dr.Dirty
Hi steer arms arent going to do what I was looking for.
Driver side looks fine
Pass side
Front is finished for now untill i figure out what what im doing with the steering arms
Dr.Dirty is offline
post #117 of 187 Old 08-12-2013, 04:29 PM
ARTEC
Vendor
ARTEC's Avatar
No need to figure it out. Proven on those knuckles and used on lots of JK swaps. Plus it'll match everything else.
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
post #118 of 187 Old 08-12-2013, 06:53 PM Thread Starter
Dr.Dirty
Id love to run those but they are out of my budget right this second.
Dr.Dirty is offline
post #119 of 187 Old 08-12-2013, 07:39 PM
wrj0003
Subbed. Awesome thread. If only. My wife is ready to shoot me because I keep showing her builds like yours and all she thinks about is the money, even though I'm usually the budget guy.
wrj0003 is offline
post #120 of 187 Old 09-09-2013, 06:05 AM Thread Starter
Dr.Dirty
Well I have decided to go a different direction on the steering. I should have no issues clearing the after market diff cover. These have 1 1/4 shanks so ill be able to also beef up the tie rod and drag link as well.
Dr.Dirty is offline
