14 bolt and HP dana 60 in a JK - Page 5 - JeepForum.com
post #61 of 187 Old 05-15-2013, 02:20 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Here's a few pictures from the rear axle. Also showing off some sick welding skills
and since I'm a man of integrity, I'll even show where I got caught changing position while running a bead and had WAY too much stick out
Anyway, point being, there is a ton of welding surface to cover. Can't go too fast or you'll warp it. Even with a really nice welding rig, you're still welding 3/8" steel when you burn the backbones to the bridge. My axle tubes are 1/2" so when burning the backbones to the tubes it's even hotter. A bit more difficult there as you're welding 1/4" to 1/2" so if you don't increase your travel speed a bit when passing over the 1/4" stuff you can burn through pretty quick. I possibly could have gotten it done quicker, but I was waiting for the welding surface to be cool enough to touch before making another pass.
Artec, thanks for chiming in on this thread. Y'all make some quality parts, everything fit together as it should. Like grown up Man-Lego's!
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #62 of 187 Old 05-15-2013, 04:02 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Mol is offline
post #63 of 187 Old 05-15-2013, 04:23 PM
222Doc
222Doc's Avatar
This is going to be one killer ride
But; lego skills are not to messed with no welding or glue, I am a master builder of Lego.
222Doc is online now
post #64 of 187 Old 05-16-2013, 01:31 PM
ARTEC
Vendor
ARTEC's Avatar
What axle are you running that the truss needed to be trimmed?
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
post #65 of 187 Old 05-16-2013, 02:09 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Solid 60 if I'm not mistaken
My builds:
and
or follow us on
spyder6 is offline
post #66 of 187 Old 05-16-2013, 03:33 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
It's a Solid HP60. They machine some flat tops on the casting with some 3/8" tapped holes for bolt on link brackets.
post #67 of 187 Old 05-17-2013, 10:54 AM
ARTEC
Vendor
ARTEC's Avatar
Cool. Just wanted to be sure. Now I know with some slight trimming the solid axle works. Thanks.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #68 of 187 Old 05-24-2013, 05:04 PM Thread Starter
Dr.Dirty
I had a few spare minutes today so I decided to do some work on the Jeep. I am not sure what form of unicorn semen they used to weld the the stock spring perches on the 14 bolt but I hope i never have to cut another set of those off.
Got the rear truss set in at 0 deg with the pinon where i want it.
Spent a while measuring and remeasuring out front and looks like the oil pan clearance is close as well
Dr.Dirty is offline
post #69 of 187 Old 05-24-2013, 06:10 PM
Dynomax_Exhaust
Dude.... I got a gut feeling you will be doing a lot of grinding on "unicorn semen" down the road after you get these in.
Have a great weekend.
Dynomax_Exhaust is offline
post #70 of 187 Old 05-25-2013, 05:41 AM
spyder6
spyder6's Avatar
2010
did somebody say... Unicorn?
My builds:
and
or follow us on
spyder6 is offline
post #71 of 187 Old 05-25-2013, 06:16 AM
Shobes
Those axles look great, nice looking welds too. This is a stupid question but being from Michigan (generous amounts of road salt in the winter) I've been trying to wrap my head around painting the artec truss. I'm thinking of getting these for my TJ D44s and I'm just curious to see how they paint up? They are extremely beefy looking though, the axle would likely rust through before the truss!
Edit: my main question here is how do you paint in between the two vertical plates that run parallel with the axle?
My "hard way" build -
Shobes is offline
post #72 of 187 Old 05-25-2013, 08:25 PM
jeepbronco1
Looking good man!
GREENERNSHlT - Homebuilds- tube fenders, infloor storage, bumpers, cage, sliders...etc
My TRUCK/SUT Build
http://www.jeepforum.com/forum/f96/jeepbronco1-sut-build-my-mini-truck-build-aka-bobbed-top-1178064/
jeepbronco1 is offline
post #73 of 187 Old 05-26-2013, 06:42 AM
Mol
Mol's Avatar
No different than an axle, control arm brackets, the frame, or any other piece of steel paints. Point a can and spray
Mol is offline
post #74 of 187 Old 05-26-2013, 12:33 PM Thread Starter
Dr.Dirty
You could always pre paint the inside and tape of the edges that need to be welded. Or use wled thru primer. I live in the desert so it takes a long time to rust so ill do my best to get as much paint in there as possible.
Dr.Dirty is offline
post #75 of 187 Old 05-26-2013, 07:05 PM
Shobes
Haha, well played
Shobes is offline
