14 bolt and HP dana 60 in a JK - Page 3 - JeepForum.com
post #31 of 187 Old 05-05-2013, 12:49 PM Thread Starter
Dr.Dirty
Dropped all my hubs and shafts off at the machine shop and the 14bolt housing at the sandblasterso ill have some more updates once it get some parts back
Dr.Dirty is offline
post #32 of 187 Old 05-07-2013, 10:07 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Originally Posted by spyder6
The sterling 10.5s already have a tone ring on the carrier. I've been curious to know if you could splice both rear sensor lines onto a single tone ring and lie to the computer. I don't see why it would fault. As far as the computer would know, you're running a Detroit in the back.
Splicing the tone ring to two sensor inputs won't work. You can run a minimum of 1 sensor and still get speedo and odometer but unless you have all 4 up and running you will end up with an ABS fault. That said, folks have places multiple sensors on a single tone ring and made that work. jeepbronco put 2 on each side of his 14B and nothing up front and it worked out fine. Great way to go so you only have to deal with machining on one of the axles rather than trying to match tooth count, bore, and overall diameter for the tone ring on dissimilar axles.
Looking forward to seeing this come together Dirt!
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #33 of 187 Old 05-07-2013, 10:14 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Good to know, though I'm not sure how i could get a second sensor to read the factory tone ring on a 10.5 due to it being inside the differential. I guess I need a 10.5 to look at and let the creativity wheels roll
My builds:
and
or follow us on
spyder6 is offline
post #34 of 187 Old 05-07-2013, 10:18 AM Thread Starter
Dr.Dirty
The trick to the factory tone rings is the tooth spacing not the tooth count.
I was going to use the Sterling rear end but didnt want to have to deal with relocating the fuel tank just yet....
Dr.Dirty is offline
post #35 of 187 Old 05-07-2013, 11:16 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
The fuel tank is a pretty easy swap. The GR setup is way overpriced. JSS has a thread on doing a TJ swap on the cheap over at JKO. Since there isn't any real need to stretch the wheelbase on a JKU it works out nicely.
post #36 of 187 Old 05-07-2013, 11:48 AM
spyder6
spyder6's Avatar
2010
Do you have a link to it? I'd get a strange feeling in my pants If I could use a savvy GTS
My builds:
and
or follow us on
spyder6 is offline
post #37 of 187 Old 05-07-2013, 02:58 PM
jeepbronco1
Looking good man ! I'm subscribed !
GREENERNSHlT - Homebuilds- tube fenders, infloor storage, bumpers, cage, sliders...etc
My TRUCK/SUT Build
http://www.jeepforum.com/forum/f96/jeepbronco1-sut-build-my-mini-truck-build-aka-bobbed-top-1178064/
jeepbronco1 is offline
post #38 of 187 Old 05-07-2013, 03:30 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Yeah buddy
http://www.jkowners.com/forum/showthread.php?t=51061
post #39 of 187 Old 05-10-2013, 10:18 AM
spyder6
spyder6's Avatar
2010
Thanks Jeffè
My builds:
and
or follow us on
spyder6 is offline
post #40 of 187 Old 05-12-2013, 03:07 PM Thread Starter
Dr.Dirty
Nothing new to report other than I did drag the 60 under the front. Ill start all the measuring and fun stuff this week.
Dr.Dirty is offline
post #41 of 187 Old 05-13-2013, 11:59 PM
AveCat
What fender flares are those?
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
2.5" Rock Krawler Lift - Bilstein 5100s - 315/70/17 Duratracs - AEV Control Arms
TruckLite - Rigid
AveCat is offline
post #42 of 187 Old 05-14-2013, 05:08 AM
spyder6
spyder6's Avatar
2010
Trail mods
My builds:
and
or follow us on
spyder6 is offline
post #43 of 187 Old 05-14-2013, 09:23 AM
DrHolliday
2011 JK Wrangler
Following this thread. Hoping to have the funds to do this sometime this year or next spring.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #44 of 187 Old 05-14-2013, 03:28 PM
AveCat
Originally Posted by spyder6 View Post
Trail mods
Love the look of those but $800 is insanely high in my opinion.
TruckLite - Rigid
AveCat is offline
post #45 of 187 Old 05-14-2013, 07:45 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Exactly what I'll be doing with mine. I'll enjoy following along.
How have you setup your rear suspension?
I'll be ordering the artec 4 link kit for the 14 bolt
https://artecindustries.3dcartstores...asp?itemid=261
Edit - don't mind me, I read right past it
Mol is offline
