-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   14 bolt and HP dana 60 in a JK (http://www.jeepforum.com/forum/f96/14-bolt-hp-dana-60-jk-1515812/)
Dr.Dirty 04-28-2013 04:08 PM
Well i told my self i wouldn't swap the axles until she was paid off well guess what!!
Im going to use a HP Dana 60 out of a 79 Ford F350 and a rear Chevy 14 bolt.
Sold both my rubi axles so now shes in the shop on stands patiently awaiting the transplant.
https://sphotos-b.xx.fbcdn.net/hphot...89347501_n.jpg
I think it will look good with 40's
https://sphotos-a.xx.fbcdn.net/hphot...32632955_n.jpg
Picked up a 14bolt SRW for $180
https://sphotos-a.xx.fbcdn.net/hphot...37567517_n.jpg
Time for the pig to loose some weight
https://sphotos-a.xx.fbcdn.net/hphot...02598458_n.jpg
Im gonna start ordering parts monday who has the best deal for gears and lockers? I think im just gonna do detroits front and rear
I am going to be converting both axles to 6 lug so i can make use of the 6 on 5.5 beadlocks i have already. It will take some creative machining but i think Butch can do it :D
https://sphotos-a.xx.fbcdn.net/hphot...81491479_n.jpg
I was hoping that the 14 bolt would be wider and give me the space to out board my rear coilovers but it is real close to the same WMS as my dana 44 is 65.5 the 14 bolt i have is 67 wms
14 bolt vs dana 44 pinion
https://sphotos-b.xx.fbcdn.net/hphot...55660125_n.jpg
https://sphotos-b.xx.fbcdn.net/hphot...78452046_n.jpg
SubAtomicGenius 04-28-2013 04:39 PM
What a monster of an axle assembly! Great stuff, very good for inspiration! :)
Dr.Dirty 04-29-2013 08:19 AM
Here are some of the brackets that ill be using. Im going to stick with the 3 link front and rear for now.
https://sphotos-a.xx.fbcdn.net/hphot...97772062_n.jpg
spyder6 04-29-2013 08:39 AM
Are you planning on fabbing in tone rings? Dynatrac has 52 tooth rings with 4.194" ID Or something like that. With a little machine work the 14b hubs will accept them on a press fit
Originally Posted by Mallow
D60 Retrofit Tone Rings from Dynatrac. Part Number DA60-2C189-B
http://i135.photobucket.com/albums/q...l/IMAG0512.jpg
For 14B hubs, a little lathe work on the back of the hubs to fit the rings. On a D60/70, simply press them on.
http://i135.photobucket.com/albums/q...l/IMAG0458.jpg
A little grinding on the brake caliper bracket, and a little trim to the plastic webbing on the OEM JK Rear sensor, and a small hole drilled for mounting the sensor.
http://i135.photobucket.com/albums/q...l/IMAG0494.jpg
Fitting the sensor.
http://i135.photobucket.com/albums/q...l/IMAG0498.jpg
Hub back on.
[img]http://i135.photobucket.com/albums/q143/jcnoll/IMAG0499.jpg[/imgl]
Caliper back on.
http://i135.photobucket.com/albums/q...IMAG0501-2.jpg
DONE!
If you only do one rear, your speedo and odo WILL WORK ACCURATELY, AND your CEL will turn off. BUT your ABS/ESP will still light up on the dash.
If you do BOTH rears, your "BRAKE" light will also turn off on the dash.
Obviously, if you do all 4, everything will operate as OEM.
:beer::beer:
Here is the dynatrac part:
DA60-2C189-E - Tone Ring, ABS, JK, D60, Rev 2 Updated .25" Wider
$69.00 each from Dynatrac
Dr.Dirty 04-29-2013 08:41 AM
Yes sir thats the plan. I am going to take my 14b hubs to my machinist ans let him see if he can turn them done and redrill them for the 6 on 5.5 bolt pattern. If not then i will be ordering a set of hubs form solid with the correct bolt pattern and then have them turned down for the tone rings.
spyder6 04-29-2013 08:44 AM
Please document the process in detail, I'd be greatly appreciative of it. I'm looking for a pair of 05+ SRW F350 axles myself with the intent of doing this.
The sterling 10.5s already have a tone ring on the carrier. I've been curious to know if you could splice both rear sensor lines onto a single tone ring and lie to the computer. I don't see why it would fault. As far as the computer would know, you're running a Detroit in the back.
jeepn4life92 04-29-2013 08:45 AM
im sure if you look around at military surplus yards, you can find a detroit for that 14b real cheap, and if youre willing to settle on 4.56's, you can get them real cheap there too. thats what military CUCV's came with in the rear...
Dr.Dirty 04-29-2013 08:48 AM
Id like to go to at least 5.13's if not 5.38s with the 40's
Dynomax_Exhaust 04-29-2013 02:12 PM
Subscribed!
Dr.Dirty 04-30-2013 07:14 PM
Well I scored a 79 Ford HP 60 toaay with 4.10s and a detroit and all new seals and bearings and new king pins. I aslo picked up a dana 60 rear end ill be listing for sale soon and 2ea 12 bolt H1 wheels and 4 ea 24 bolt H1 wheels and 6 37 inch BFG bajas.
https://sphotos-a.xx.fbcdn.net/hphot...12697440_n.jpg
https://sphotos-a.xx.fbcdn.net/hphot...27499252_n.jpg
spyder6 04-30-2013 07:18 PM
jealous
Dr.Dirty 04-30-2013 07:26 PM
All the artec goodies will be here tomm so hopefully these will be under the jeep soon. Now i just have to find time to get it all done up
spyder6 04-30-2013 08:52 PM
what process are you doing to convert the 14b to disk
Dr.Dirty 04-30-2013 08:59 PM
Ill ordered brackets form diy4x4 and ill use the gm 3/4 ton calipers and rotors
http://diy4x.com/cart/image/cache/tn...sc-400x400.jpg
spyder6 04-30-2013 09:03 PM
cheby i assume
The time now is 02:46 AM.
