'13 jk unlimited A/c question. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > '13 jk unlimited A/c question.
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 07-16-2014, 04:09 PM   #1
88notchback
Hello everyone, new guy here with a simple question. I got a '13 unlimited wrangler, when I get in and start it the a/c never come on right away. Instead the defrost post button blinks for around 30-45 seconds then when it stops the a/c or fan will come on. Anyone have any information on this or is it normal? At 104 degrees you start to really sweat within that short period.
88notchback is offline   Reply With Quote
Unread 07-19-2014, 05:52 PM   #2
OrcaSupreme
I would say that is not normal. My '13 JKU's AC fires up right away. Now the fan does take a 5 second narcoleptic nap every once in a while, but only after it has been running for a while.
OrcaSupreme is offline   Reply With Quote
Unread 07-20-2014, 03:50 PM   #3
varnerme
Does that nap happen when the outside temperature shows 75 degrees? Mine does it almost every time. No idea why or if it matters? Always makes me a little nervous it won't start again.
1995 YJ
2013 JKUR
varnerme is offline   Reply With Quote
Unread 07-22-2014, 05:34 AM   #4
OrcaSupreme
I don't think so, but you have given me something to check for now. I hadn't noticed any rhyme or reason for when it happened. If the trigger turns out to be "75*", that will at least give the dealership something to go on.
- Dave
