12 mpg on highway?? - Page 2 - JeepForum.com
post #16 of 51 Old 07-05-2010, 10:41 PM
ncb
Unless you know exactly how many gallons it took to top off the tank after the trip your math is inaccurate.
ncb is offline
post #17 of 51 Old 07-05-2010, 10:58 PM
ak67sd
you need to go through a few tanks to get a better average, and fill the tank and reset the trip odometer... you will have 100+ miles left with the fuel light on!
ak
08 Wrangler Unlimited
ak67sd is offline
post #18 of 51 Old 07-05-2010, 11:29 PM
Imped
Imped's Avatar
OP--no such thing as an 06 UL Sahara unless you're talking about the limited edition Sahara Rubicon.
OlllllllO
IndyORV
Imped is offline
post #19 of 51 Old 07-06-2010, 12:17 AM
MacK
2015 JK Wrangler
Have you checked your air filter?
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline
post #20 of 51 Old 07-06-2010, 01:13 AM
planman
Thanks to all Mod erators
planman's Avatar
Automatic JKs suck due to the 0.69, ubber-tall overdrive gear.
They come way undergeared stock.
To run the same rpms at 70 mph as a 6 speed, automatic Rubicons would need 4.88 gears with stock tires.
Because automatics are way undergeared stock, they downshift frequently in windy or hilly situations.
When the transmission downshifts, it "flashes the converter." This essentially runs the rpm levels higher than would otherwise be reached with the overdrive turned off, and it does this at almost wide open throttle.
So, in order to get the same gas mileage with an automatic as you did with your Sahara 6 speed, you would have to regear to a low enough gear to avoid downshifting, or slow down enough so the tranny does not downshift.
Wind resistance from speed, hills, cross-wind, and stock axle gearing with an automatic are not a conducive combination for good mpg.
FYI, my wife's automatic Rubi 4dr on 37s gets over 20 mpg at 65 mph with 5.38 gears and a Superchips Flashpaq programmer.
My 2dr Rubi 6 speed when on 37s got over 20 mpg at 65 mph with 5.13 gears and a Superchips Flashpaq programmer.
planman is offline
post #21 of 51 Old 07-06-2010, 03:15 AM
Warlord2
Holy crap, thats 5mpg more then what I get with 35's and 5.13's doing an average 60-65 hand calculated with a gps. Did the Superchip Flashpaq make any difference? I didnt think a manual would even need one. I know I should coast at a lower rpm on the hwy once I get 37's but I never thought it would make THAT much of a difference...
ps: how is your mpg on the 40's?
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #22 of 51 Old 07-06-2010, 03:21 AM
MilitaryJK4455
2010 JK Wrangler
I just got back from a trip to GA. I was running 60 at about 1900 RPMs in 5th gear with 3.73's and 35's and I was averaging 19mpg. Tested it on 2 tanks... Got 19 on one and about 18 on the other.
MilitaryJK4455 is offline
post #23 of 51 Old 07-06-2010, 08:52 AM
planman
planman's Avatar
Not so great with the 40s. It dropped 2-3 mpg. I still get about 12-13 mpg in town, but at 65 mph it dropped to 16-18 mpg--depending on crosswind and hills.
JP Magazine rated tuner/programmers and determined the Flashpaq was good for a 7% increase in mpg. So that would be 1 mpg.
If you run your tires at about 32 psi on the highway, you might gain another 1-2 mpg.
I do have a Cherry Bomb glasspack exhaust. Maybe that is good for 0.5-1 mpg.
I gps verified distance and speed, and I hand calculated mpg. The in-dash computer is actually very close.
planman is offline
post #24 of 51 Old 07-06-2010, 09:46 AM
08rubinewb
Where did he say 06?
08rubinewb is offline
post #25 of 51 Old 07-06-2010, 09:53 AM
Dronac
I get 21 mpg at 80 mph with my 2 door JK X.
It's lifted, is Flashpaq tuned, air dam removed, 3.73 gears, auto tranny, and 32'' tires.
Iv found it helps to find a SUV to drive behind. Not tailgate, but just enough to help with the wind resistance.
2008 Jeep JK X: auto trans, 3.73 gears, D44 rear, D30 front
Mods: 2'' Rusty's coil lift, Superchips 93 octane tune, Cobra 75 CB radio, 33'' Duratrac's, onboard air compressor
My Build Thread! ---> http://www.jeepforum.com/forum/f96/dronacs-build-thread-1104134/
Dronac is offline
post #26 of 51 Old 07-06-2010, 10:30 AM
GPV
You give me hope...........................
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #27 of 51 Old 07-06-2010, 02:31 PM Thread Starter
quag1509
2010 JK Wrangler
The in dash showed 14 mpg and on the way back not using cruise control I was able to get 15.3mpg. I did the math wrong initially but still should be getting better mileage with a stock Rubi.
quag1509 is offline
post #28 of 51 Old 07-06-2010, 02:50 PM
Shalamar
2010 JK Wrangler
Easily. My Rubi Unlimited is an Auto, but the in dash MPG calculator showed 19.8 at the end of my trip.. and that included a fair amount of stop-and-go holiday traffic on the return!
My Rubicon is bone stock as well.
Shalamar is offline
post #29 of 51 Old 07-06-2010, 02:58 PM
nygader
2010 JK Wrangler
Sounds like something is wrong. I just did over a 3,000 mile trip with a '10 Rubicon Unlimited - Automatic and I averaged around 17 mpg for the whole trip. I was getting 16 up North going up and down all of the hills and 18 was I got down south where it was flat. The cruise was set on 74 to 78 depending on traffic flow. By the way South Carolina had the best gas prices - $2.39 a gallon.
nygader is offline
post #30 of 51 Old 07-06-2010, 03:51 PM
daggo66
2009 JK Wrangler
Originally Posted by waterboarder View Post
That's about what I get - 12, 13MPH.
You don't drive very fast do you?
Tom
daggo66 is offline
mpg , gas mileage , jk , wrangler
97 TJ all over the highway, help 763ersma27 TJ Wrangler Technical Forum 19 02-09-2010 06:45 AM
4.88s on the highway?? b0bbymc TJ Wrangler Technical Forum 32 07-16-2009 02:26 PM
Highway RPM danj TJ Wrangler Technical Forum 22 02-23-2009 06:23 PM
Highway MPG? BigCanoe JK Wrangler Technical Forum 26 04-24-2008 11:54 AM
10.9 MPG on highway tx-Skydiver JK Wrangler Technical Forum 12 02-26-2007 10:16 AM
