'12 JKUR rear locker blowing fuse - JeepForum.com
post #1 of 17 Old 04-14-2014, 09:56 PM Thread Starter
skrach77
2005 WK
I am having an ongoing issue with my rear locker. Everytime I try to engage it, it blows the fuse for the lockers. I have tried running a new power and new ground wire for it, still blows the fuse. If I unplug the rear locker at the diff, I can call for the rear (which just blinks) and then the front, and the front engages immediately.. Any ideas?
skrach77 is offline
post #2 of 17 Old 04-14-2014, 10:53 PM
SubAtomicGenius
2011 JK Wrangler
Sounds like the solenoid coil or the internal wiring for the locker is shorted out.
You can disconnect the wire at the locker and measure the resistance across the terminals (locker electro-magnetic coil). I'm not sure what the resistance should be exactly.... however, if you read a low resistance - i.e. very near or at zero for a short circuit - your current will increase over the fuse rating and the fuse will blow everytime you throw the switch.
SubAtomicGenius is offline
post #3 of 17 Old 04-14-2014, 11:06 PM
ronjenx
ronjenx's Avatar
The coil on the locker I have, which works well, is 3.8 ohms.
Could be the electromagnet in the locker has rotated, pulling the wires out of it, and the bare wire ends are shorted together inside the differential housing.
ronjenx is offline
post #4 of 17 Old 04-15-2014, 12:19 AM
SubAtomicGenius
2011 JK Wrangler
Should be about 3 amps to operate it at 12 volts. What size is the fuse?
post #5 of 17 Old 04-15-2014, 06:33 AM Thread Starter
skrach77
2005 WK
It's a 20 amp fuse
skrach77 is offline
post #6 of 17 Old 04-15-2014, 06:37 AM Thread Starter
skrach77
2005 WK
I've got this evening to figure it out. I leave for Moab for EJS first thing tomorrow. It's so frustrating to be getting to take the jeep trip of my dreams, and my jeeps broken
skrach77 is offline
post #7 of 17 Old 04-15-2014, 11:41 PM Thread Starter
skrach77
2005 WK
I've got the rear diff cover off right now, and the ring that the wires connect too has some play in it- is that normal?
skrach77 is offline
post #8 of 17 Old 04-16-2014, 07:44 AM
ronjenx
ronjenx's Avatar
Is the anti-rotation tab properly engaged on yours?
What direction, and how much play do you have?
Can you rotate it? Or can you slide it back and forth sideways?
ronjenx is offline
post #9 of 17 Old 04-18-2014, 09:29 PM Thread Starter
skrach77
2005 WK
In mine, that tab is not fully engaged and rather than the pin being square, it's noticeably worn on one corner. The other piece does rotate some back and forth as it hits that worn pin. I don't remember any side to side play, but have slept a little since I had it apart.
skrach77 is offline
post #10 of 17 Old 05-01-2014, 12:15 PM Thread Starter
skrach77
2005 WK
So here's an update, it's kinda funny- we unplugged my locker and ran a jumper loop to a buddy's locker in his jeep, and my jeep saw it, locked it, and the light in my dash worked like it's supposed too.
Problem has to be in my locker
skrach77 is offline
post #11 of 17 Old 05-01-2014, 01:01 PM
MudDuck99
2014 JK Wrangler
is it still under warranty?
MudDuck99 is offline
post #12 of 17 Old 05-01-2014, 03:32 PM
mrwhipple
Drive train warranty should cover it. 5yrs/100,000 miles
silver jkur
mrwhipple is offline
post #13 of 17 Old 05-01-2014, 06:28 PM
222Doc
222Doc's Avatar
sounds like the wire going into the electromagnet shorted out.
222Doc is offline
post #14 of 17 Old 05-02-2014, 11:17 AM Thread Starter
skrach77
2005 WK
I'm not the original owner, no warranty. I'm thinking it's the wires inside as well
skrach77 is offline
post #15 of 17 Old 05-02-2014, 11:57 AM
ridesno4llfe
Factory warrenty follows the vehicle with the exception of the lifetime warranty. Check with jeep it should have coverage.
Everytime I sell a jeep I say no more then a new one shows up in my driveway
ridesno4llfe is offline
