12+ Auto Rubicon Tcase info wanted - JeepForum.com
post #1 of 5 Old 07-09-2015, 05:33 PM Thread Starter
Valpacer
2007 WK
Hi Folks,
Im over here from the Grand forums chasing some info on the 2012+ Auto (Nag1) Rubicon transfers cases Please!
Im chasing some measurements of the input shaft length from the mounting face and confirmation that the mounting pattern is the same as the earlier rubicon cases.
If you can help that would be great!
Thanks
Dave
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #2 of 5 Old 07-09-2015, 08:54 PM
rich6700
Mounting pattern is the same, input shaft spline count not sure.
rich6700 is offline
post #3 of 5 Old 07-09-2015, 09:08 PM Thread Starter
Valpacer
2007 WK
Thanks Rich,
It has a male spline but i only need the total length
Valpacer is offline
post #4 of 5 Old 07-10-2015, 08:51 AM
222Doc
222Doc's Avatar
everything i have ever read says the 2012 Rubi Tcase will not fit any JK,TJ unless it has the nag1 /w580 auto as well. I think it is Rob that has the info? he does Ls conversions. Even posted pics of the section you are thinking about
222Doc is online now
post #5 of 5 Old 07-10-2015, 04:34 PM Thread Starter
Valpacer
2007 WK
Thanks for that mate, ill see if i can track him down.
Im trying to work out if i can retrofit into a WK grand (which has the nag1 auto but a very different mounting surface and bolt layout) so that why im chasing the length to see how much room im playing with for an adapter to mate the two.
And you are correct it wont fit any other JK or TJ.
They are just very rare down here as a second hand unit so not having much luck finding the info local
Valpacer is offline
