10A Bumper Mods - JeepForum.com
post #1 of 8 Old 09-24-2013, 09:44 PM Thread Starter
MoonyJohn
10A Bumper Mods
Hello all, Im picking up a front bumper tomorrow from the 10th anniversary rubicon and I just want to know what you have done to yours. Id like to get a hoop for it and eventually get a winch sometime down the road, just curous what people have done out there!
Also, where do they mount the license plate?
MoonyJohn is offline
post #2 of 8 Old 09-25-2013, 09:49 AM
spinlock
The 10A bumper has license plate mounting hole right in the middle. It's about the only flat area on the bumper.
I have not seen a hoop for this bumper just the winch kit. The Mopar light bar should work because it attaches to chassis where the bumper mounts.
spinlock is offline
post #3 of 8 Old 09-25-2013, 11:16 AM
wrh3
http://www.maximus-3.com/10th-anniversary-rubicon.html
Hoops and winch mounts.
Bill - 2012 Rubicon / 2013 Rubicon 10A
billswebspace.com
wrh3 is offline
post #4 of 8 Old 09-25-2013, 08:50 PM Thread Starter
MoonyJohn
Originally Posted by wrh3 View Post
Perfect! Thanks
What about wiring for the fog lights from an 08 to the new H16 wiring harness from the fog lights?
post #5 of 8 Old 09-26-2013, 08:40 AM
wrh3
I would try and find someone that has cutoff their H16 plugs and has no plans to go back to OE- cut and splice with waterproof crimp connectors, I imagine the wire colors should be the same but easy enough to test with a volt/ohm meter.
billswebspace.com
wrh3 is offline
post #6 of 8 Old 09-26-2013, 09:12 AM Thread Starter
MoonyJohn
What are the chances of finding some? They sell on eBay for 26 bucks a piece, no way!
post #7 of 8 Old 09-26-2013, 12:02 PM
Vin
Perfect! Thanks
Have you taken out the lights in the 10A bumper? I remember seeing a post where someone was having difficulties because the lights couldn't be moved into his new upgraded bumper.
Vin is offline
post #8 of 8 Old 09-26-2013, 06:02 PM Thread Starter
MoonyJohn
I took the bracket out, but the light is mounted pretty tricky. You could probably get it out, chances are your going to break it though. Id like to upgrade to some Warn wireless ones eventually but I can see how they would mount up if the bracket wont allow the stock one to come out
I ended up soldering the fog lights to make them work. Its not pretty, but it works so I covered it up good so no one can see them
