102" whip CB antenna mount locations. - JeepForum.com
post #1 of 4 Old 09-09-2013, 09:06 PM Thread Starter
Neo1130
2015 JK Wrangler
Where have you guys mounted your 102" whips on your JK? I liked the CoolTech, but it's pretty damn spendy. I can also lay the whip down and forward for when I need to go in parking garages, etc... I like the one between the back door and spare tire, however, not many options to lay it down when needed. Keep in mind I have a soft top and kids so I don't want them getting smacked with the top down, etc... Feedback is appreciated! Would like to buy a mount soon.
Neo1130 is offline
post #2 of 4 Old 09-09-2013, 09:44 PM
AveCat
From jk-forum user gunuck
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
2.5" Rock Krawler Lift - Bilstein 5100s - 315/70/17 Duratracs - AEV Control Arms
TruckLite - Rigid
AveCat is offline
post #3 of 4 Old 09-09-2013, 09:45 PM Thread Starter
Neo1130
2015 JK Wrangler
I like that! Is that a custom mount?
Neo1130 is offline
post #4 of 4 Old 09-09-2013, 10:07 PM
AveCat
Here's the post verbatim...
"Hope it works and you can see my installation.
I used a piece of stainles angle plate and attach inside the hinge using existing bolt.
Extended post is not necessery, but it was used on previos antena that had top coil and I wanted the coil above roof line.
If you can find wider angle so the antena mount leg is further away from the door. Thats why I left the riser.
Also you can run the coax trough the gate, but do not try to feed it trough door wiring harnes, leave it on the outside.
I did that on my 08 and in the winter the coax got mangled inside the harness.
TruckLite - Rigid
AveCat is offline
