1 person soft top removal? - Page 2 - JeepForum.com
post #16 of 19 Old 09-13-2012, 06:03 PM
zamball
2009 JK Wrangler
I always stand in the back seat and pull the header bar up and over. Works the best.
2009 JK Rubicon 2.5" RC lift | Drop in K&N filter | Bully Dog GT Gas Tuner
2007 WK CRD 3.0 Stock for now...
zamball is offline
post #17 of 19 Old 09-13-2012, 07:07 PM Thread Starter
Gomofast
Gomofast's Avatar
Thanks guys, I took your advice and I was able to do it from inside the jeep, lifting up in the middle. Guess I was just surprised because I could always do my TJ top from outside the vehicle.
08 JK Unlimited X, 2" Black Diamond lift, 33's, 1.5" wheel spacers, stubby bumper mod.
98 TJ Sport, 4" Rough Country Lift, homemade discos,
35" BFG Mud Terrain T/A KM's, 4.56 gears, Detroit Truetrac
up front, factory Trac-Lok out back,Warn M8274 8000lb
winch, York OBA, rock guards, custom intake, 48" HI Lift.
Gomofast is offline
post #18 of 19 Old 09-14-2012, 10:28 PM
Durhamjeeper
One person from the outside
Once you unhook everything, pull up one front corner.
Reach in the gap you created - yes the header looks torqued.
Grab the bar that does not attach, but has Y ends and runs the full width.
Push that bar upward - the header will even out and that bar will be the fold point for the top going into the sunrider position.
Loosen the clip on the side you are on to release the next stage of the removal.
Walk around and loosen the other one.
Unhook the rear corners from the tub and either fold them over the top, or tuck them into the elastic loops used to hold the rolled-up back window.
As you slowly lower the remainder of the top, work the folds in like an accordian.
Once it is completely down, you can remove the 4 torx screws and pull the ends of the bows off the brackets.
Grab one set of the bows in one hand and wrap your other arm around the folded top.
Now you can completely remove it and store it while going topless.
Durhamjeeper is offline
post #19 of 19 Old 09-15-2012, 10:09 AM
paul84043
There were times where I had the soft top locked on for an extended time and it kind of stuck in the corners. So I would break the corners loose first, and after that it was easy to lift the top from one side only.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
one person , soft top
Hardtop Removal/Storage Solution - One Person Operation DeepSky JK Wrangler Technical Forum 42 11-30-2011 05:42 PM
Single Person JK Hardtop Removal?? Corleone JK Wrangler Technical Forum 39 06-22-2010 02:14 AM
One Person Soft Top Operation tylerd JK Wrangler Technical Forum 12 06-12-2009 09:53 PM
One person spring removal/install Snuffster TJ Wrangler Technical Forum 21 03-15-2007 09:59 PM
soft top removal Thug Nasty TJ Wrangler Technical Forum 19 04-21-2006 03:50 PM
